Components help
Discussion in 'Troubleshooting and Repair' started by Angelo, Sep 12, 2014.
  1. Angelo
    Angelo
    30
    Sep 10, 2014
    hello,
    i have a sot23 with reference "CR"22, on the case i see A6W
    What it could be ?
    Also, it is near to something similar to a buzzer, that's named "LS"1, but of square shape with small hole in the middle, that measures 43ohm.
    thanks
  2. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    BAS16 diode I think.
    Adam
    Angelo likes this.
  3. Angelo
    Angelo
    30
    Sep 10, 2014
    thanks, it could be, i de-soldered and measured it, act as diode. LS1 is really a buzzer.
  4. davenn
    davenn Moderator
    13,903
    1,971
    CR has been used for diodes since semiconductor diodes have been around
    it sorta depends on country of origin and the learning history of the circuit designer
    as to if CR or D is used
    Same with transistors -- T, TR, Q
    and voltage regulator IC's -- VR, SR, IC
    can get confusing for new comers to the hobby ;)
  5. Angelo
    Angelo
    30
    Sep 10, 2014
    thanks,
    i admit that i never seen CR for diodes, anyway, good to know.
  6. (*steve*)
    25,500
    2,840
    Agreed.
