Components for trade or low cost
For Sale: Discussion in 'For Sale / Wanted' started by BOsborne, May 19, 2011.
Thread Status:
Not open for further replies.
  1. BOsborne
    BOsborne
    May 18, 2011
    Just a small sample of components that I have collected over the years.
    Unlike most sellers at Ebay, I don't try to make money from shipping.
    I will send by the lowest cost and not charge for packaging. I get free packaging from my
    work place from our shipping department, so I recycle our received items packages.
    I am here to help fellow electronics enthusiasts like myself.
    I have several of each of these. You can find the Data Sheets for them here:
    http://www.datasheetarchive.com/
    uA715HC high speed op amp
    uA733HMQB Differential Video Amplifier op amp
    MC14011BAL Motorola 2-Input NAND-Function Logic Gate
    9601DMQB Retriggerable One Shot
    DM7430N 8-Input NAND Gate
    MC6802 Microprocessor with clock and optional RAM
    MC10105L Triple 2-3-2-Input OR/NOR Gate
    MC10125L Quad MECL to TTL Transistor
    MC10131L Dual Type D Master-Slave Flip-Flop
    MC14050 HEX Buffer
    7430N 8-Input NAND-Function Logic Gate
    10524 Quad Ttl-to-mecl Translator
    54165DMQB 8-Bit Parallel-to-Serial Converter
    9601DC Retriggerable Monostable Multivibrator
    AM27S21DC 1,024-Bit (256 x 4) Bipolar PROM DATA SHEET: http://www.datasheetarchive.com/pdf-datasheets/Datasheets-115/DSAP00731.html
    ICL7109CPL Maxim Integrated Products 12 Bit A/D Converter With 3-State Binary Outputs DATA SHEET: http://www.datasheetarchive.com/pdf-datasheets/Datasheets-18/DSA-346047.html
    CA3028B/3 RCA General Purpose Differential Amplifier - high rel.
    S68B21P American Microsystems Peripheral Interface Adapter (PIA) - Peripheral I/F Adapter
    SN54155J Texas Instruments Dual 2 Line to 4 line Decoders/Demultiplexers
    SNJ54S02J Texas Instruments QUADRUPLE 2-INPUT POSITIVE-NOR GATES
    MC6840P Motorola Semiconductor Programmable timer module, 1 MHz
    SN74LS86N Motorola / Freescale Semiconductor QUAD 2-INPUT EXCLUSIVE OR GATE
    2N3823 Motorola N-CHANNEL JUNCTION FIELD EFFECT TRANSISTOR 4 pins
    JAN2N1613 Microsemi Corporation NPN Transistor
    2N2369A Texas Instruments SMALL SIGNAL NPN TRANSISTOR TO-18
    2N2484 Fairchild Semiconductor NPN low level low noise amplifier.
    93L425PC Fairchild General-Purpose Static RAM - Includes separate CE, WE cntrl
    D2148H Intel General-Purpose Static RAM - Icc 150mA max
    RM4156DC Raytheon Electronics Quad General Purpose Op Amp - Compensated
    TRW52602 TRW RF power transistor 2GHz QTY. (2) http://www.advancedsemiconductor.com/pdf/mln2033f.pdf
    MC14046B Motorola Phase Locked Loop
    ICM7218AIJI Intersil Corporation 8-Digit LED Microprocessor-Compatible Multiplexed Display Decoder Driver.... QTY. (1)
    DS8830N National Semiconductor Dual Differential Line Driver
    LF347BN National Semiconductor Wide Bandwidth Quad JFET Input Operational Amplifier
    LM324AN Motorola Operational Amplifier, General purpose, Quad channel, 32V, DIP, 14-Pin
    CA3028A RCA Differential/Cascode Amplifiers from DC to 120MHz
    LM311N ST Microelectronics Comparator, Single channel, Open drain/collector, 36V, DIP, 8-pin (QTY. 2)
    I have a plethora of other components that I will post also.
    I'm looking for a TDA7000 FM Receiver IC.
    Trimmer caps 2-45 pf range
    Hi frequency power transistors
    electret condenser microphones
    330pf ceramic caps
  2. Neotron
    Neotron
    17
    Mar 9, 2012
    Got any VINTAGE components like semiconductors esp. with packaging or unused?
Thread Status:
