Component identification ?
Discussion in 'Electronic Basics' started by Mike Steward, Jul 18, 2004.
  1. Mike Steward
    Mike Steward Guest
    I have an ever growing stock of electronic components: transistors, IC's,
    voltage regulators, in various case styles. Many of which are brand new.
    My problem is identifying them. Does any one know how I should go about
    identifying them.
    Mike S.
  2. CFoley1064
    CFoley1064 Guest
    Subject: Component identification ?
    Hi, Mike. Figure out which of the numbers on the device refer to the part
    number, and do an NTE component search
    http://nte01.nteinc.com/nte/NTExRefSemiProd.nsf/$$Search?OpenForm
    When you punch in a part number they may recommend an NTE cross reference. The
    description of that part will give you an idea what your part does. This works
    particularly well with diodes, transistors, SCRs and triacs. NTE also has many
    ICs such as voltage regulators and opamps which they also cross reference.
    If you have them available, sheets of anti-static foam can be used for storing
    the ICs, which are particularly susceptible to ESD (electro-static discharge).
    Good luck
    Chris
  3. Puckdropper
    Puckdropper Guest
    Sometimes a Catalog like the Radio Shack catalog can help identify the
    components also. You get a picture of different case styles, etc...
    Puckdropper
  4. Art
    Art Guest
    MCM Electronics has a rather extensive free catalog.
