Component identification help
Discussion in 'Troubleshooting and Repair' started by Adroc3905, Jan 13, 2014.
  1. Adroc3905
    Adroc3905
    Jan 13, 2014
    Hi Everyone,
    New to the forum, hoping to get some help.
    I need to replace what appears to be a diode of some sort on a 2.4ghz RF board as it has burned up. The board itself still operates however I am sure this diode had a purpose and would prefer to replace if at all possible. I however have no idea what component specs to search for. The first pic is of my board with the damaged component (upper right corner of board), the second is a pic I found online of the board with the component intact.
    The markings 47 and 20V are not really bringing up any good search results.
    Any help is very much appreciated.
  2. davenn
    davenn Moderator
    13,798
    1,939
    Hi there
    welcome to the forums :)
    its a 47uF 20V capacitor
    relatively rare for those to blow unless you reversed the power supply ??
  3. Adroc3905
    Adroc3905
    Jan 13, 2014
    Thank you so much!
    The RF module is from an RC transmitter I purchased from a buddy.....who is not always vigilant with his gear. It would not surprise me if he connected the tx battery with reversed polarity at some point, surprising it still operates.
    Is there a particular one I am looking for?
    Here are some links to what I have found thus far:
    http://www.ebay.com/itm/10-KEMET-T4...714?pt=LH_DefaultDomain_0&hash=item33893e5cf2
    http://www.mouser.com/ProductDetail...GAEpiMZZMukHu%2bjC5l7YT7nTOiGKP3dHBrUadO3rz4=
    http://www.mouser.com/ProductDetail...GAEpiMZZMukHu%2bjC5l7YW8lyOIPs0RDtyMw872cN/Y=
  4. (*steve*)
    25,482
    2,830
    There's probably not that much difference between any of them. I'd offer the normal cautions about buying from eBay though.
    I'd be feeling very lucky that the unit still operates if it has had the power connections reversed.
