Comparators with diodes on the output why?
Davewalker5
Sep 20, 2014
125
Sep 20, 2014
125
I don't understand why there is diodes on the output of these comparators? any reason
Is it about sinking and sourcing current?
Because a comparator with switch from a low state to a high state, so the diode does what?
(*steve*)
¡sǝpodᴉʇuɐ ǝɥʇ ɹɐǝɥd
25,510
25,510
Because the design requires it. The outputs are "OR"ed together.
Davewalker5
Sep 20, 2014
125
Sep 20, 2014
125
ORed together how so ? i don't see it
The comparator goes high or low, how does the diodes make the comparators output ORed?
Supercap2F
Mar 22, 2014
550
Mar 22, 2014
550
Lets say that you drop the diodes from the circuit, so you have two comparators outputs tied together. Now if one of the comparators output goes high, and the other ones output is low, your going to get a short. But if the diodes are there, only high voltages will pass through them eliminating the shorts that could happen on the output.
Putting the diodes there instead of a OR gate is just to save IC packages count. Some people call this technique "Mickey Mouse Logic" or M2L.
Dan
(*steve*)
25,510
25,510
I'm sorry, you'll have to figure that out for yourself.
If you wonder why, you should google "askhole"
Davewalker5
Sep 20, 2014
125
Sep 20, 2014
125
Yes I understand
So both comparators outputs can be HIGH and it won't short out? or damage the output stage internally of the op amp?
Now I do see how the diodes are a OR, when you "TIE" both outputs of op amps together
Davewalker5
Sep 20, 2014
125
Sep 20, 2014
125
So the voltages don't add or the current add when the 2 outputs are HIGH?
I guess since both outputs are at the same potential they don't add together
kpatz
Feb 24, 2014
334
Feb 24, 2014
334
The diodes are needed since 741s can both source and sink current, meaning if one is "high" and one is "low" current would flow between them in a nearly short circuit.
If comparators with open-collector outputs like the LM339 were used, the diodes wouldn't be needed, since these devices only sink current, they can't source it.
davenn
14,261
14,261
nice answer Kpatz :)
ya taught me something
Davewalker5
Sep 20, 2014
125
Sep 20, 2014
125
How can a 741 op amp source current?
The diodes are in series , so how can a diode in series sink current?
I can understand if the diode was in parallel with the output, it would sink the output
I'm confused about how it's sources or sinks current
Since op amps aren't open collector outputs, what is their internal output called?
Open collector outputs can only sink current , they can't source current because of why?
davenn
14,261
14,261
Open collector
that shows you why they don't source current
if you don't understand what to sink current or to source current means then google those terms
its pretty straight forward
An IC with an output that is a current sink will have its NPN transistor with emitter connected to the internal GND (0V) and current is sourced from external circuitry into the collector
An IC with an output that is a current source will have its PNP transistor with emitter connected to the internal V+ and current is sourced from the collector
kpatz
Feb 24, 2014
334
Feb 24, 2014
334
As davenn explained, an op-amp or comparator IC can be designed to source current (PNP transistor output, so a positive current flows from the V+ rail to the output), or sink current (NPN transistor output, so a current flows from the output to GND). An op-amp IC typically has both the PNP and NPN outputs together, so it can source or sink current depending on what it sees at its input. This is also known as a push-pull configuration.
Op-amps are push-pull so they can output a variable voltage (as the "push" and "pull" sides can act as a variable voltage divider) as an amplifier is designed to do, while comparators are used more in a "digital" fashion (on or off) so they are usually open-collector so that the outputs can be tied together without needing diodes. This is probably the biggest design difference between comparator and op-amp ICs.
