Compaq V710 pin-out
Discussion in 'Electronic Repair' started by Peter Louwerse, Dec 1, 2003.
  1. All,
    I recently was given a Compaq V710 with a few missing pins in the VGA
    plug. I've been trying to figure out witch color corresponds to witch
    pin but was unable to do so due to the fact that the plug was filled
    up with some kind of filler. Could some please help
    Tnx & regards,
    Peter Louwerse
  2. BFriedl
    BFriedl Guest
    Google is your friend here
    http://www.google.com/search?hl=en&ie=UTF-8&oe=UTF-8&q=vga+pinout&spell=1
    BFriedl
    A+ Certified Technician
    AIM: UACybercat
    ** Bear Down Arizona! **
    ******* Go Cats! *******
  3. Thnx but the problem i'm facing is a little more complex. I have no
    knowledge of CRT electronics and do not know which V710 wire color
    corresponds to which function. The cable has 9 colored wires 5
    'normal' ones (purple, yellow, black, white and orange) and 4 wires
    with a mantle(?) (green, red, blue and gray). My guess is dat the ones
    with the mantle are the primary RGB + Ground signals but what are the
    others?
    Regards,
    Peter Louwerse
  4. BFriedl
    BFriedl Guest
    Oh, sorry about that. Well i suppose you could use a multi-meter to test
    for continunity between pins to figure out where most of them go. Then
    you should only have 1 wire left..your missing pin! Or, perhaps someone
    here has a service manual and can give you a definate answer.
    BFriedl
    AIM: UACybercat
