Compact flash prototyping.
Discussion in 'Hobby Electronics' started by Duong Nguyen, Oct 1, 2004.
  1. Duong Nguyen
    Duong Nguyen Guest
    I'm looking for a way to mechanically interface a compact flash card
    to a homemade wire-wrapped CPU card. Where in Oz can I buy one of
    those 50-pin connector (probably with an ejector handle)? Is there any
    other way? Is memory stick etc. any easier?
  2. Farnell have the connectors.
    CF card is complex, but *much* simpler than memory sticks, which are all
    USB, and require a USB host ( read PC with Windows ) to operate.
    Regards,
    Adrian Jansen adrianjansen at internode dot on dot net
    Design Engineer J & K Micro Systems
    Microcomputer solutions for industrial control
    Note reply address is invalid, convert address above to machine form.
  3. Duong Nguyen
    Duong Nguyen Guest
    Thanks. After about 10 minutes and getting nowhere on Farnell web site
    I switched over to RS and found one (M120-50PD-SF, AUS$ 7.79)
  4. Lord-Data
    Lord-Data Guest
    I dont think memory stick has any interface system other than as "storage"
    anyway ..
    Compact Flash and SD are the only formats I know of that have an "IO" mode
    as well as storeage .. and even SDIO is very under-implemented ..
  5. Brenton
    Brenton Guest
    Jaycar have CF card sockets for about five bucks. They are SMT and don't have
    eject latches or the like but are great for proto work.
  6. Moses Lim
    Moses Lim Guest
    i m no electronics expert nor a computer genius .. but USB is also widely
    supported on Linux ...
