A
AggieSawDust
My buddy dropped his ReplayTV off at my place the other day for me to
take a look at. It turns out that one of the power supply output pins
had a blown transistor attached to it. After further inspection, I saw
the middle leg (Base or Gate, couldn't tell what kind of transistor it
was) was cut and not connected to anything. This was apparantly done
by design since none of the other two transistors attached to output
pins had their middle legs connected to anything either.
So anyway, best I can tell, these were designed to be used as fuses
(that must make these normally closed transistors JFETs, right?). Not
being too experienced, I've never run across this. Is this a common
practice? Wouldn't it make sense to use actual fuses to make servicing
easier?
-Patrick
easier?
-Patrick
