Common mode chokes for radio module?
Discussion in 'Radio and Wireless' started by eem2am, Jul 21, 2021.
  1. eem2am
    eem2am
    422
    Aug 3, 2009
    We are using the ESP32-C3-MINI-1 chip as a wi-fi transceiver.
    ESP32-C3-MINI-1 Transceiever datasheet:
    https://www.espressif.com/sites/default/files/documentation/esp32-c3-mini-1_datasheet_en.pdf
    Forgetting for a moment that about the RF side of thsi chip, ..the chip receives/transmits data by copper tracks into its pins 30 and 31 respectively.
    These signals go to a connector which accomodates a cable which goes off board. We are concerned about this cable acting as an antenna and creating a radiated emissions problem.
    As such, we wish to put a common mode choke(s)/ferrite bead in these traces, right by the connector. Can you recomend any ferrite beads or common mode chokes for this? I presume since there are three lines (RX,TX and GND), that really a common mode choke is not practical, and that a ferrite bead in each line would be best?
  2. Harald Kapp
    11,533
    2,656
    I agree. Common mode choles are good for preventing common mode noise on differential lines. Your signals are not differential. On the contrary, should it so happen that the transmitted signal is equal or very similar to the received signal (this may happen or not, depending on what's going on in your communication), a common mode choke would suppress the signal.
    This paper on "IMPROVING NOISE IMMUNITY FOR SERIAL INTERFACE" may help youalong.
