A
AJ
I am looking for opinions on grounding techniques, particularly in
automotive circuits. I have designed a circuit that uses both digital and
analogue circuits and I was planning to connect these grounds at a single
point to attempt to keep digital noise away form the analogue section. I am
also using a switch mode power supply operating at 300KHz so I was thinking
of using a common mode choke on the input to help EMC. I was wondering the
best way to connect this, I am a bit confused......
I connect positive and ground to one side of the choke so on the other side
I will have a filtered positive and a filtered ground. Does this then give
me a 3rd ground? I was thinking about connecting the unfiltered ground to
the Chassis and running a ring around the outside of my PCB on both layers.
I was then going to connect the digital ground the filtered output after the
choke and connect the analogue ground like described above Some circuits I
have seen appear to have the ground connected together before and after the
choke so I cant see what the pint is of filtering the ground in the first
place in that example..
I hope I have been clear on what it is that I am trying to do and really
appreciate any feedback
Best Regards
AJ
Best Regards
AJ
