Common Base Biasing
W
Warren
I am curious about common base configuration biasing. When
using a _split_ supply, how are the emitter and collector
resistors chosen?
VCC
| | RC
RE | | |
'-' GND
VEE
1) I assume that you start with a desired Ic current.
2) Given that the base is DC grounded (in this example at
least), then it follows that the top of RE is -0.6V.
3) So I assume that you compute RE = (VEE-0.6) / Ic.
It appears that the collector can only swing between near
ground and +VCC, so I would assume you target VC at VCC / 2.
4) Hence Rc = (VCC / 2) / Ic.
Is that the overall procedure?
I know you can also arrange it so the base is only AC
grounded, which then allows greater flexibility for choosing
input/output impedances, not to mention output swing. But you
often see this configuration listed as an example.
W
Warren
Phil Hobbs expounded in
Yes, that's more or less it. As you say, there are usually
other considerations, notably input impedance, bandwidth,
and power dissipation. If the source has a lot of shunt
capacitance, the layout is crappy or the transistor is
really fast, you might need a base resistor to suppress
oscillation.
Cheers
Phil Hobbs
Thanks Phil. I think I'm finally getting a handle on this,
after all these years.
Reading Ch 2 of the Art of Electronics made the BJT biasing of
emitter follower, common emitter (and implicitly) common
collector configuration biasing easy. I only wish I had known
that 30+ years ago.
Everything else I've ever read seemed to make it so
complicated with h-parameters etc. Finally some common sense
prevails for a simple guy like me.
Warren
Jamie
resistors chosen?
VCC
| | RC
RE | | |
'-' GND
VEE
That looks good, I always look at that type of config as voltage
divide with a little loss to it. They are good how ever at
converting and semi isolation of signals.
Jamie.
josephkk
that 30+ years ago.
Warren
Yikes. Trying to learn how to bias a transistor with the h-paramter black
box model? Crikey, that was made artificially difficult. Must have been
the only thing the prof understood.
I learned bjt bias with the simplified-t model, then moved to the
hybrid-pi model.
The two-port h-parameter and a, y, and z equivalents are to be used at the
next higher level, for chains of amplifier / filter stages.
