Can someone tell me what must be done in the SSB transmitter and in a
SSB receiver to compensate for the lack of a full carrier in SSB
transmission?
Any advise regarding this would be appreciated.
Thank you
Is this a trick question? Are you talking about how it's demodulated,
or are you looking for a perceived need for making sure the receiver
is on the exact frequency when there's no carrier to tune to?
Since other's have explained the former, just for fun I'll take a stab
at the latter.
Much of the time, you don't. A slightly mistuned receiver simply sounds
a tad odd, since the recovered audio will not be exactly where you expect
it. If you've mistuned by 10Hz, that 1000Hz tone will be 1010Hz. Since
very little transmitted by SSB is more complicated than voice, one can
usually live with it. Or looking at it another way, SSB is not used to
transmit music since the mistuning will make the music sound awufl.
If you want exact, you start with a crystal controlled transmitter,
and a crystal controlled receiver, and in some cases the crystals go
into a crystal oven.
I don't know if there are situations where a transmitter is sending
data on one sideband and voice on the matching other sideband, but
the data channel would provide a means of proper tuning since you would
know what's being sent on the data channel.
Some attempts at broadcasting with SSB have cheated, either using
a full carrier or an attenuated carrier. But then it's single sideband
with a full or partial carrier.
Fifteen to twenty years ago there was talk of using a similar scheme
for two-way SSB, particularly at VHF and UHF. I have no idea if this
ever saw much application, but it was done by inserting a subaudible tone,
in effect a carrier, albeit not where the actual carrier is. Filter it out,
and you've got the marker for proper tuning. But again, it's not pure
single sideband without carrier.
Realistically, the one useful purpose the carrier serves is to ensure
that the signal is tuned properly at the receiver.
Of course, if one can make do with double-sideband with a suppressed
carrier, the receiver does know where to put the reinserted carrier.
It's always half-way between the sidebands, and since the upper and lower
sidebands are mirror images of each other, that does point to where
the mid-point is.
Michael
