Colour sensing module
Discussion in 'General Electronics Discussion' started by DIJO PAUL, Jun 22, 2013.
  1. DIJO PAUL
    DIJO PAUL
    Jun 22, 2013
    Is there any idea to detect colours?
    I am on the way in designing such a module, please share your opinions.
  2. davenn
    davenn Moderator
    13,808
    1,943
    a digital camera and appropriate software
  3. (*steve*)
    25,489
    2,830
    Light sensors and filters
  4. gorgon
    gorgon
    603
    24
    Jun 6, 2011
    As Steve say, the simplest way to go is RGB filters and 3 optical sensors. This together with some processing algorithms in a microcontroller should make a decent colour analyzer.
  5. GonzoEngineer
    GonzoEngineer
    321
    Dec 2, 2011
    Google "Spectrophotometers"
  6. Raven Luni
    Raven Luni
    798
    8
    Oct 15, 2011
  7. (*steve*)
    25,489
    2,830
    Yes, I was thinking of them too. Essentially a 1 pixel colour camera :)
  8. NuLED
    NuLED
    294
    Jan 7, 2012
    I would assume from these descriptions that, using RGB filters, the detector will figure out the magnitude of each primary color (voltage level of the photo detector?), and then use an algorithm to calculate the color that had these RGB values.
  9. (*steve*)
    25,489
    2,830
    Well, probably your code inside a uC or whatever will determine the colour.
    The question is, what do you want to do? It may just be a case of determining a certain broad range of values which represent a target value, or it may be much more complex.
