Jackie said:
Under AUD$1000.
Jackie
that
Jackie,
Just check out any of the Aussie PC mags (APC or PC abUser) for ideas on
what's available.
Also a post in aus.computers or a similar computer related NG might get you
more responses.
AAMOI, I have a Konica-Minolta 2300W (about $700) and have had no problems
with it. Can connect via parallel port or USB but it is not a network
printer, although you can print from other PCs on your network provided the
host PC is on. Alternatively you could use a cheap print server.
One thing you will find with all low cost laser printers is the cost of
consumables - pretty high compared to some larger machines. If you don't
intend to do large amounts of printing, then a sub $1000 colour laser is
probably your best option.
Cheers,
Alan
