Color code for home alarm wiring
I am building a new home and it comes standard with a alarm pre-wire.
I have over 30 years experience with electronics, but not with alarms.
I plan to buy a Power 832 or vista-20P and install it myself. Could
someone provide me the standard wiring color code, or point me to a
web site.
Thanks for any help or advise, Bob T
N
Nick Markowitz
You are on your own figuring the wiring out because many prewires i have
seen are deliberately fooled with to keep DYI from working on it.
you are going to have to use a ohm meter and meter the wiring out.
The standard wiring code notmally is red is pos neg is black and white and
green is the trip loop but iyou can find all different combinations in
systems.
goodluck.
C
Crash Gordon
There's not standard per se. A lot use red/black for power, yellow/green or
white/green for the loop.
Every now and then I'll run across some takeover that used the total
opposite scheme which always drives me nuts as it's not logical to me
| web site.
R
Robert L Bass
web site.
For most systems the wiring is simple enough. Using 22/4 solid
cable, red is +12V; black is -12V; white or yellow is zone return
and green is common. Keypad runs are similar, except that green
and yellow (or white) are for data.
You're welcome. I have an online alarm store called
www.BassBurglarAlarms.com
Regards,
Robert L Bass
Bass Burglar Alarms
The Online DIY Store
http://www.BassBurglarAlarms.com
B
Bob Worthy
in message
or stranded. I see more problems with solid down the road, than with
stranded, but that is open to opinions. Nothing says you have to use one
over the other.
of course you do. You advertise it every chance you get here on the
newsgroup
called
www.Bigass Bass Bungler Alarms.com
Check B B B in Sarasota, Florida.
C
Crash Gordon
i've always preferred solid over stranded for 90% of my installs...but fail
to see how you'd color code differently for stranded vs. solid :))
Years ago ADT wire used to have blue instead of green (I think it was
green)...boy that through my installers into a tizzy :-0 --- I bought
hundreds of thousands of feet of it since no one wanted non-standard colored
wire...what a deal I got!
| "Robert L Bass" wrote in message
| over the other.
| newsgroup
| called
B
Bob La Londe
Bob Worthy said:
in message
over the other.
There are advantages and disadvanatages. I can't say I have seen any
problems with solid over stranded once an installation is complete. There
are a couple things that enter in for a prewire during construction. Any
wire tags that wind up hanging out of doors or windows tend to get torn up
from opening and closing. The stranded tends to hold up marginally better
to this abuse. Unfortunatley the stranded is much more limp making it
difficult to leave a bit of slack up in the wall or ceiling. I use the
solid because I can make an accordiin bend back and forth in my hand about
five times and leave it inside the frame of the house. This gives me abut 2
feet of slack to work with. When I come back to do a tie down I grab the
wire hanging out of the hole and pull it down. Then I completely cut off
the stub that was sticking out. This totally eliminates any wire damaged
from the opening and closing of the door or window.
It has taken me some time to education the construction supervisors and the
door and window trim guys I work with but I have most of them pretty well
trained. I don't know how many 3/8 drill bits I have given away to guys I
have cornered and explained that I will invoice for charge backs if I have
to cut a hole in the wall to find my wire, but I have very few problems with
my installs.
I even have most of the drywall and lathe guys watching out for my boxes.
About ten years ago I had a drywall guy cover half dozen boxes on three
houses in a row. I tried to talk to him about it and all I got was a loud
guffaw! "Haw Haw HAW!" About the thrid gufaaw he broke the dry wall in two
walls. He accidentally fell down and when he fell he went right between the
studs in the first wall and smashed into another wall. When I helped him up
I might have accidentally walked through another section drywall in the same
wall with my shoulder so I get to him quickly and help him up. I year or
two ago I stared telling that story around construction sites for
contractors I work with regularly. My drywall problems still happen, but
its almost always an honest mistake now, not just too lazy to measure a box
and make a cut.
The funny one, was a lathe guy. About a year ago this guy comae over to a
house I was prewiring and asked me how much I would charge back for covering
a box on the outside of a house. I explained that it is difficult to
precisely locate a box undcer chicken wire and stucco. This often leaves
you cutting out a larger section of stucco and hoping you can find the box
in the first cut. If its just a box with conduit and that doesn't have any
wire in it then its even harder. Then you have to break out an angler
grinder to make the cut with a masonry blade or a circular saw with a
diamond blade. A dirty nasty job. If all goes well then you just have to
get somebody out to patch the stucco. Then you have to come back after the
stucco patch is done to finsih the job. Including extra travel it can cost
you several hours of time. Thats if you have the right tools to do the job.
I don't imagine that many residential low voltage contractors carry and
angle grinder and a cable locator in their truck. They probably have a tone
and probe, but it just doesn't work well through chicken wire and stucco.
Add on that many guys don't label their prewires. They tie down devices and
then work backwards to determine which wire they tied down. This means that
before you can located a covered wire you have to identify the other end.
"So, Mr Lathe guy? What did this electrician charge you to locate his box?"
Oh, and don't forget while he is doing several extra hours of work because
of your mistake he is falling behind on this job, and other jobs that should
be making him money aren't getting done. "Did I tell you about the drywall
guy who laughed so hard about covering my boxes that he fell down
accidentally breaking through two walls?"
Bob La Londe
http://www.YumaBassMan.com
LocalNet dialup IMO is a criminal organization.
Have not used them in years but they continue to bill me.
O
Okitoki
Now I have another topic that should raise some eyebrows...
Why in all of these years do we use +12V and -12V? In electronics, the
difference is 24Volts!! In Electronics you should use +12V and 0V. But
they use plus and minus on everything!! On panels, on batteries,
everything! Could someone technically explain why -12V is used instead
of 0V's?
Thanks!
F
Frank Olson
of 0V's?
Thanks!
Because.
B
Bob Worthy
We used to use solid, as a standard, many years ago, when working for a
national company. I switched, when on one particular type of system, that we
were installing, required us to keep going into different areas of the
system and adding more buildings over the years. Eventually, we started
getting opens on the circuits. It seemed the problem was always at the
splice point. Not the new one, but the existing ones in the same area.
Granted, it wasn't the best application, but it was, as is in most of todays
applications, two wires spliced together with beans, beanies, crimps or what
ever other term people use. The crimps have very sharp little teeth inside
to penetrate the outer jacket of the wire. I think that it might be
possible, that with that style crimp, those teeth just may be scoring,
notching, or damaging the solid copper core, leaving it weaker than normal.
When people are back into the splice, where there is always that possibility
of bending or repeated movement of the wire, the copper could break within
the jacket at the splice. Maybe we were using the wrong crimps, or maybe we
should have been using blocks but in any case, the average installer is
going to use the most popular method and that is crimps. The problem went
away with stranded wire.
There
to this abuse.
Agreed
Here in Florida, we don't have that luxury. There is only a 3/4" cap between
the sheet rock and the cement block and we have to make a block shot
diagonally from the wall to the window. We need flexibility.
Must be nice
We have to drill either a 3/4" or 1" hole into the window or door buck and
curl our service loop up into that. Again, needing the flexibility. The new
hurricane codes have the doors and windows bolted tight tight tight to the
sub frame with no caps. Not as easy as the old days.
Working in S. Florida, where everything is concrete and steel they do.
Bottom line is that you are right. I am sure there are advantages and
disadvantages to both from area to area and mostly boils down to preference.
F
Frank Olson
web site.
Any of the keypads for the systems you purchase will have the wiring
colours pretty well labelled. Red (+), Black (-), Green and Yellow for
"data". The colours aren't really important. What is, is that you
maintain a uniform "colour code" throughout your installation. We use
yellow and black for contacts, green and red for negative and positive
power on devices that require it. On a lot of panels, the keypads use
the same "aux power" terminals as the other devices on the system (DSC
happens to be one of the exceptions to this). Using the standard keypad
colour code suggested by the manufacturer and the wire colours I
mentioned for other devices' power (red and green), you can very quickly
differentiate the keypad runs from the rest of the system. This could
cut your troubleshooting time down by several minutes on the larger
systems. When it's time to identify your wire runs, you can find more
information here:
http://www.yoursecuritysource.com/markingcable.htm.
Good luck!!
Frank Olson
R
Rocky T Squirrel
do a reference voltage check against the loop ckt and you;ll notice a -12 at
some point.. also some panels use a reverse current to help supervise a
circuit (ie.. fire outputs, spkr outputs)
((always a reason))
RTS
N
Nick Markowitz
On the european equiptment i work on in plants 0 voltage is used almost
exclusive with USA it is always 12v- unless they are following the ICE
coding standard used in europe which is 0 voltage.
It is probably another one of those 230vac 50hz vs 120/240 60 hz deals
C
Crash Gordon
One "feature" I like about solid is when/if it breaks...it breaks..gone,
switch to the spare pair, with stranded you may have 18 of 19 strands
broken...leaving one lonely strand holding the circuit.
Besides, I hate working with stranded...takes longer to do makeups.
one
| > > over the other.
we
todays
what
normal.
possibility
we
| > There
Any
up
better
| > to this abuse.
| Agreed
about
between
| Must be nice
off
damaged
new
preference.
R
Robert L Bass
You're right. Technically it's wrong but that's the common usage
and people are used to seeing it that way -- knowing that the
intended meaning is "12VDC".
BTW, I get a kick out of people who ask, which wire is positive
when they're talking about an AC circuit.
Regards,
Robert L Bass
Bass Burglar Alarms
R
Robert L Bass
installs...but fail to see how you'd color code differently
I'm not sure whether you're replying to me or to W. Like you,
I've always preferred solid core cable for most things. I
usually used stranded cable for siren speakers and the
transformer. Most everything else gets solid core cable. I'm
used to handling it and can manage to strip the stuff without
nicking the inner conductors (probably what causes problems for
some of these folks).
Speaking of color codes though, every so often I'd get a box of
22/4 stranded cable and for some reason the fourth wire was white
-- not green. Clearly there's not a different color code for
stranded but for some reason that's the way it was.
Years ago ADT wire used to have blue instead of green...
Quite a few years ago they used to use something called "rainbow"
wire. It had a clear sheath and I forget how many inside
conductors, each of a different color. They would run this stuff
around the basement from one junction box to the next. At each
box they would splice whatever sensors or key stations (*not*
keypads) were nearby to the appropriate wires. Once you knew the
color code you could work on any of their systems.
These were ancient systems in southern New England. They may or
may not have actually been ADT originally. They bought out
several other old companies around the time when Methuselah was
cutting his baby teeth. :^)
Regards,
Robert L Bass
Bass Burglar Alarms
B
Bob La Londe
I have always been told to use stranded for sound... except that telephone
audio obviously propogates very well over solid.
Anything that moves gets stranded.
Bob La Londe
R
Robert L Bass
except that telephone audio obviously propogates
That last line said it all, Bob. Speakers and other audio gear
tend to get moved around a lot. Thus they are usually connected
using stranded cable.
As for audio propagation, there's zero difference between solid
and stranded cable. Anyone who tells you otherwise is either
trying to sell you something, listening to audio salesmen spout
pseudo-scientific drivel or Olson. None should be believed.
Regards,
Robert L Bass
Bass Burglar Alarms
M
Mark Leuck
Actually that isn't true
F
Frank Olson
Heh... I don't need to spout any sort of "drivel" at all when Google is
a far more accurate record. You do more to confirm your own stupidity
on a daily basis than I ever could.
Speaking of cabling for speakers, here's a very interesting article
someone emailed me.
http://www.audioxpress.com/reviews/media/504hansen1203.pdf
Frank Olson
