Coles Digital Set Top Box
D
Dave Goldfinch
I have just bought a "Music Television" Model MTV-540STB set top box
from Coles for the incredible price of $75.
I am in WA so I don't know if this is available nationally or just in
WA.
It is a nice neat unit & setting it up is a doddle. Reception appears
to be excellent - but then my analogue reception is also very good so
YMMV.
It even has a RS232 port for firmware upgrades !
S
Stuart Palmer
WA.
YMMV.
Hi Dave,
It's here in Victoria at least - was looking at it myself.
Thanks for the info.
Does it have aspect ratio control on the remote, or do you have to fish
through menus to adjust it?
Thanks again.
D
Dave Goldfinch
Hi Dave,
Thanks again.
It has an 'ASPECT' button on the remote - THe manual quotes it as
offering 'Full Screen, Letter box or Pan Scan'.
It even has 3 games built in ! (Tetris, Boxman and Happy Snake)
S
Stuart Palmer
Cheers again Dave, thanks.
P
Phil Allison
"Dave Goldfinch"
WA.
YMMV.
** What are the video options ?
Has it got S-Video or Component Video ( 3 x RCAs) ?
Has it got a SCART socket or a mini-DIN for S-Video ?
......... Phil
M
Mr.T
You need to establish if there are any still available first. When Coles say
"no rainchecks" it means they don't intend to have much stock.
MrT.
D
Dave Goldfinch
"Dave Goldfinch"
......... Phil
Hi Phil
Video is limited to Composite and S-VHS.
Audio is analogue stereo and Digital audio.
HTH
D
Dave Goldfinch
Hi Phil
HTH
The S-VHS socket is a mini-DIN.
P
Phil Allison
"Mr.T" T = Turd.
** CRIMINAL context snipper !!!!
& CRIMINAL idiot assumption maker !!!!
** What the **** for ????????
.......... Phil
P
Phil Allison
"Dave Goldfinch"
"Phil Allison"
** Excellent.
Are you using the S-Video ?
........... Phil
P
Phil Allison
"Dave Goldfinch"
** Cool.
That makes it one up on the DSE budget STUB.
......... Phil
D
David L. Jones
Phil said:
"Dave Goldfinch"
My Thomson STB has a 3.5mm stereo socket for the S-Video connection.
Not uncommon these days.
Dave :)
D
Dave Goldfinch
"Dave Goldfinch"
** Excellent.
.......... Phil
Unfortunately not - my aging TV doesnt have that option.
Hopefully the price of widescreen sets will drop enough for me to
contemplate buying one soon.
P
Phil Allison
"Dave Goldfinch"
** Nearly all sets have it now.
A very decent 68cm with full AV can be bought for under $400.
** No need for that expense to appreciate the HUGE improvement S-Video
makes.
Use it with your DVD player too.
Digital TV and typical DVD quality are practically the same.
.......... Phil
M
Mr.T
Phil Allison said:
"Phil Allison" = Turd.
CRIMINAL idiot !!!!
Pardon me for assuming your questions had some point to them.
MrT.
P
Phil Allison
"Mr.T" T = TURD
** **** YOU for PIG ARROGANTLY assuming YOU knew the reason.
.......... Phil
D
David L. Jones
Phil said:
"Dave Goldfinch"
makes.
IMHO a widescreen set with composite is better than a 4:3 with S-Video
any day. Hang out for the widesreen set Dave, I think a 76cm can be had
for around $600 or so these days. 100Hz is worth paying the extra for
though.
The majority of digital TV content is widescreen, so doesn't look
nearly as good on a 4:3 set. You can zoom in of course, or fit to
screen, but then you either lose content or have a distorted image.
Yep, much better than analog.
Although I still find that you can see the compression artefacts in
high speed sports footage which I find a bit annoying sometimes.
Dave :)
P
Phil Allison
"David L. Jones"
any day.
** Absolute bullshit.
Using composite blurs the pic and colour quality on any screen.
though.
** The vast majority of SD TV is in "letterbox " mode.
Plus nothing looks WORSE than a 4:3 image on a wide screen set - that
means many movies and even some commercials.
** Neither is true.
** Not inherent in the SD format - but a result of deliberate limiting of
bit rates by the networks.
An SD signal can have a higher bit rate than a DVD.
......... Phil
M
Mr.T
Yes, it was stupid of me to assume you would ever have a point to your
arguments.
MrT.
