D
David L. Jones
A rather unusual question...
I am looking for a way to calculate the coherence value of two signals
which are several cycles of a fixed frequency sinusoidal like waveform.
i.e. I need a single value in the range 0-1 for the coherence of the
two waveforms.
I have tried calculating the coherence using the standard formula:
|Sxy|^2 / (Sxx.Syy)
where Sxy is the Cross Power Spectrum and Sxx and Syy are the AutoPower
Spectrums
and then extracting the value of the single frequency I am interesed in
from the frequency domain response.
But the coherence specturm calcuation using this technique is only
valid with averaged data samples, and I only have *one* set of sampled
data for each waveform, so I always get a result of 1.0 regardless of
the actual coherence between the two waveforms.
Does anyone know of a way to calculate coherence, or a "coherence like"
result for *non-averaged* data that gives a result from 0 to 1 for two
similar sine waves?
Any help appreciated.
two waveforms.
|Sxy|^2 / (Sxx.Syy)
Spectrums
similar sine waves?
