Coaxial to PCB connection
Discussion in 'PCB Layout, Design and Manufacture' started by Tripp, Jul 7, 2014.
  1. Tripp
    Tripp
    4
    Jul 3, 2014
    Hello all,
    Im rebuilding an old Veroboard circuit buy desinging a dedicated PCB. The original board has a coaxial cable that has been split to get pos and neg in/outputs. The circuit works but Im sure there must be a neater way to connect these cables, at the moment the wires from the cable are twisted and soldered to bits if wire bent in a U shape which looks rubbish.
    Is there a type of crimp to pin adaptor as that would work fine.
    Regards,
    Tripp
  2. Harald Kapp
    10,990
    2,496
    You can use a coaxial PCB mount connector.
    Or simply use trough-holes in the PCB matching the diameter of the twisted wire ends, setthe wire ends into the holes and solder them in place.
Similar Threads
Loading...
