coaxial test PCB pattern
F
FrankW
Hello Group
Has anyone come across a PCB foil pattern which
can accomodate a test probe for a coaxial type connection
In other words something that would eliminate a SMA
type connector for certain boards that fail and need to be probed.
Using some sort of coaxial test probe.
Thanks in advance
John Larkin
Hello Group
Thanks in advance
We just use a pth for the signal and another nearby for ground, and
use a fast high-impedance (fet or sampling) probe.
How fast is the signal? Must the probe be a 50-ohm cable?
Oh, you can also just do the SMA pattern with tight holes and just
sort of press in a connector temporarily.
Or use a permanent but cheaper surface-mount connector, like the
Hirose things.
John
F
FrankW
Those tiny,cheap SMT connecters will do the trick.
