R
Robert L Bass
What's a better location for an AC wall plug-in type of
Place the CO detector on a wall about 5 feet above the floor.
Carbon monoxide is slightly lighter than air but it mixes thoroughly with
room air so it does not accumulate at the ceiling. Optimal detection is at
"breathing" height which for most people is about 5 feet from the floor.
That is the recommendation of at least one major manufacturer. There is
some disagreement on this subject among CO detector manufacturers. Last I
checked NFPA doesn't give any guidelines on detector height.
Likewise there are varying opinions as to where the detectors should be
placed in a home. I like to install them near sources of carbon monoxide
and in hallways outside of sleeping rooms. Some folks believe that one or
the other of these locations is sufficient. Absent a code specification I
figure it's best to err on the side of caution and cover both. Thus I would
install detectors in the furnace room, any room with a fireplace or gas
operated appliance and another outside the bedrooms. It's usually best not
to install CO detectors inside bedrooms because the propellant in hairspray
can set them off.
Wherever you install them, make sure they are tested regularly, especially
at the start of the heating season. I have information on several brands of
carbon monoxide detectors on my website at
http://www.bassburglaralarms.com/subcategory_256.htm. If the home is heated
using LPG you might also want to consider installing combustible gas
detectors such as those I list on a companion page at
http://www.bassburglaralarms.com/subcategory_257.htm. These pages are for
the general public. If you're in the trade you can order these detectors
wholesale at your favorite alarm distributor.
Regards,
Robert L Bass
Bass Burglar Alarms
http://www.BassBurglarAlarms.com
http://www.Bass-Home.com
CO alarm: a wall socket a few inches off the floor, or a
wall socket mid way up the wall ?
Why ?
can set them off.
Regards,
Robert L Bass
Bass Burglar Alarms
