CMOS Circuit for Negative Voltage Generator
Discussion in 'General Electronics Discussion' started by Eugene66, Jul 4, 2008.
  1. Eugene66
    Eugene66
    Jul 4, 2008
    Hello,
    Does anyone have any good references for a CMOS low noise low current negative voltage generator.
    Thanks very much
    Eugene
  2. Resqueline
    Resqueline
    2,848
    Jul 31, 2009
    There's one example at freecircuitdiagram.com/2008/09/02/negative-supply-from-single-positive-suply-using-cmos-inverter/
    I'd run it at 30kHz instead of 3, so I could use smaller filter capacitors (1uF).
    Not sure what your definition of low noise is though.
    If you instead of 4 parallell inverters use 2 parallell inverters in series with 2 parallelled inverters then you can get full-wave rectification using 1 extra capacitor & diode. This may give lower ripple on the output.
