cmos circuit analysis
Discussion in 'Electronic Design' started by Michael Robinson, Apr 18, 2012.
  1. I'm trying to analyze this circuit's step response. It's a current source,
    with the output at the drain of M14.
    This is a modification of an earlier circuit that I wanted to improve the
    stability of. That circuit didn't have mosfet M16, just a wire connecting
    M9's drain to M15's source.
    It range in response to switching. It's because of huge gain in the loop
    that goes around M6, M11 and M14.
    I'm trying to explain why M16 has a stabilizing effect.
    It looks like signals go through M16 in both directions. As far as the
    siignal through the feedback loop I mentioned, the signal travels from M16's
    drain to its source. M16 acts like a low pass filter in this case, because
    there's no parasitic capacitance from the drain to the source; as far as the
    feedback signal is concerned M16 is a common base amplifier in which all the
    parasitic capacitances go to ground (whether to the base or to the bulk) so
    together with the mosfet's output resistance, it forms a low-pass filter. Is
    this a valid explanation?
    Here's an LTSpice netlist
    Version 4
    SHEET 1 3160 752
    WIRE 352 -256 256 -256
    WIRE 368 -256 352 -256
    WIRE 560 -256 368 -256
    WIRE 576 -256 560 -256
    WIRE 768 -256 576 -256
    WIRE 784 -256 768 -256
    WIRE 976 -256 784 -256
    WIRE 1184 -256 976 -256
    WIRE 1200 -256 1184 -256
    WIRE 688 -192 496 -192
    WIRE 1104 -192 688 -192
    WIRE 368 -176 368 -256
    WIRE 560 -176 560 -256
    WIRE 432 -160 416 -160
    WIRE 496 -160 496 -192
    WIRE 496 -160 432 -160
    WIRE 512 -160 496 -160
    WIRE 768 -160 768 -256
    WIRE 1184 -160 1184 -256
    WIRE 688 -144 688 -192
    WIRE 720 -144 688 -144
    WIRE 1104 -144 1104 -192
    WIRE 1136 -144 1104 -144
    WIRE 352 -128 352 -256
    WIRE 368 -128 352 -128
    WIRE 576 -128 576 -256
    WIRE 576 -128 560 -128
    WIRE 784 -112 784 -256
    WIRE 784 -112 768 -112
    WIRE 1200 -112 1200 -256
    WIRE 1200 -112 1184 -112
    WIRE 432 -80 432 -160
    WIRE 432 -80 368 -80
    WIRE 976 -48 976 -256
    WIRE 368 -32 368 -80
    WIRE 368 -32 288 -32
    WIRE 368 -16 368 -32
    WIRE 976 0 912 0
    WIRE 384 32 368 32
    WIRE 1120 32 1024 32
    WIRE 1184 32 1184 -64
    WIRE 1184 32 1120 32
    WIRE 288 64 288 -32
    WIRE 320 64 288 64
    WIRE 976 80 976 48
    WIRE 992 128 976 128
    WIRE 1184 128 1184 32
    WIRE 928 160 -64 160
    WIRE 1200 176 1184 176
    WIRE 256 208 256 -256
    WIRE 560 208 560 -80
    WIRE 624 208 560 208
    WIRE 768 208 768 -64
    WIRE 1136 208 768 208
    WIRE 560 224 560 208
    WIRE 768 224 768 208
    WIRE 976 224 976 176
    WIRE -64 272 -64 160
    WIRE 560 272 544 272
    WIRE 784 272 768 272
    WIRE 992 272 992 128
    WIRE 992 272 976 272
    WIRE 624 304 624 208
    WIRE 624 304 608 304
    WIRE 720 304 624 304
    WIRE 368 320 368 80
    WIRE 368 320 320 320
    WIRE 720 336 720 304
    WIRE 928 336 928 304
    WIRE 928 336 720 336
    WIRE 368 352 368 320
    WIRE 560 352 560 320
    WIRE 768 352 768 320
    WIRE 976 352 976 320
    WIRE 976 352 768 352
    WIRE 128 384 0 384
    WIRE 384 400 384 32
    WIRE 384 400 368 400
    WIRE 544 400 544 272
    WIRE 560 400 544 400
    WIRE 784 400 784 272
    WIRE 784 400 768 400
    WIRE 992 400 992 272
    WIRE 992 400 976 400
    WIRE 1120 400 1120 32
    WIRE 320 432 320 320
    WIRE 624 432 624 304
    WIRE 624 432 608 432
    WIRE 720 432 624 432
    WIRE 1152 448 1120 448
    WIRE 720 464 720 432
    WIRE 928 464 928 432
    WIRE 928 464 720 464
    WIRE 128 480 128 384
    WIRE 1072 480 128 480
    WIRE -64 512 -64 352
    WIRE 0 512 0 464
    WIRE 0 512 -64 512
    WIRE 256 512 256 288
    WIRE 256 512 0 512
    WIRE 304 512 256 512
    WIRE 368 512 368 448
    WIRE 368 512 304 512
    WIRE 384 512 384 400
    WIRE 384 512 368 512
    WIRE 544 512 544 400
    WIRE 544 512 384 512
    WIRE 560 512 560 448
    WIRE 560 512 544 512
    WIRE 768 512 768 448
    WIRE 768 512 560 512
    WIRE 784 512 784 400
    WIRE 784 512 768 512
    WIRE 912 512 912 0
    WIRE 912 512 784 512
    WIRE 976 512 976 448
    WIRE 976 512 912 512
    WIRE 992 512 992 400
    WIRE 992 512 976 512
    WIRE 1120 512 1120 496
    WIRE 1120 512 992 512
    WIRE 1152 512 1152 448
    WIRE 1152 512 1120 512
    WIRE 1184 512 1184 224
    WIRE 1184 512 1152 512
    WIRE 1200 512 1200 176
    WIRE 1200 512 1184 512
    FLAG 304 512 0
    SYMBOL pmos4 416 -80 R180
    SYMATTR InstName M1
    SYMATTR Value CMOSP
    SYMATTR Value2 l=1u w=100u m=1
    SYMBOL nmos4 608 224 M0
    SYMATTR InstName M2
    SYMATTR Value CMOSN
    SYMBOL voltage 256 192 R0
    WINDOW 123 0 0 Left 2
    WINDOW 39 0 0 Left 2
    SYMATTR InstName V1
    SYMATTR Value 3.3
    SYMBOL nmos4 608 352 M0
    SYMATTR InstName M3
    SYMATTR Value CMOSN
    SYMBOL pmos4 512 -80 M180
    SYMATTR InstName M4
    SYMATTR Value CMOSP
    SYMBOL nmos4 320 352 R0
    SYMATTR InstName M5
    SYMATTR Value CMOSN
    SYMBOL nmos4 720 224 R0
    SYMATTR InstName M6
    SYMATTR Value CMOSN
    SYMBOL nmos4 720 352 R0
    SYMATTR InstName M7
    SYMATTR Value CMOSN
    SYMBOL nmos4 928 352 R0
    SYMATTR InstName M9
    SYMATTR Value CMOSN
    SYMBOL pmos4 720 -64 M180
    SYMATTR InstName M10
    SYMATTR Value CMOSP
    SYMBOL nmos4 1136 128 R0
    SYMATTR InstName M11
    SYMATTR Value CMOSN
    SYMBOL pmos4 1136 -64 M180
    SYMATTR InstName M13
    SYMATTR Value CMOSP
    SYMBOL nmos4 1024 -48 M0
    SYMATTR InstName M14
    SYMATTR Value CMOSN
    SYMBOL voltage -64 256 R0
    SYMATTR InstName V2
    SYMATTR Value PULSE(0 3.3 0 10n 10n 1u 2u)
    SYMBOL nmos4 1072 400 R0
    SYMATTR InstName M12
    SYMATTR Value CMOSN
    SYMBOL nmos4 928 80 R0
    SYMATTR InstName M15
    SYMATTR Value CMOSN
    SYMBOL voltage 0 368 R0
    SYMATTR InstName V3
    SYMATTR Value PULSE(3.3 0 0 10n 10n 1u 2u)
    SYMBOL nmos4 320 -16 R0
    SYMATTR InstName M8
    SYMATTR Value CMOSN
    SYMBOL nmos4 928 224 R0
    SYMATTR InstName M16
    SYMATTR Value CMOSN
    TEXT 1296 -216 Left 2 !.MODEL CMOSN NMOS (
    LEVEL = 49\n+VERSION = 3.1 TNOM = 27 TOX =
    9.3E-9\n+XJ = 1.5E-7 NCH = 1.7E17 VTH0 =
    0.5637114\n+K1 = 0.8583586 K2 = -0.0589493 K3
    = -2.7574793\n+K3B = 1.1436533 W0 = 1E-8 NLX
    = 1.564468E-7\n+DVT0W = 0 DVT1W = 0 DVT2W =
    0\n+DVT0 = 0.477499 DVT1 = 0.2847938 DVT2
    = -0.3800695\n+U0 = 439.1496114 UA = 1.002561E-13 UB
    = 1.939998E-18\n+UC = 5.397035E-11 VSAT = 9.657595E4 A0 =
    1.0779238\n+AGS = 0.217566 B0 = 9.363617E-7 B1 =
    5E-6\n+KETA = -4.775643E-3 A1 = 1.963373E-4 A2 = 1\n+RDSW
    = 645.5504862 PRWG = 2.192005E-14 PRWB = -0.1195021\n+WR = 1
    WINT = 9.644098E-8 LINT = 9.038343E-8\n+DWG = -1.724548E-8
    DWB = -8.255139E-9 VOFF = -0.15\n+NFACTOR = 2.5 CIT
    = 0 CDSC = 2.4E-4\n+CDSCD = 0 CDSCB = 0
    ETA0 = 1\n+ETAB = -0.0136728 DSUB = 1.1083961 PCLM =
    0.9566763\n+PDIBLC1 = 2.227565E-3 PDIBLC2 = 4.305101E-3 PDIBLCB
    = -0.0336439\n+DROUT = 0.0499231 PSCBE1 = 3.326709E8 PSCBE2 =
    4.836604E-6\n+PVAG = 0.1980844 DELTA = 0.01 RSH =
    4.3\n+MOBMOD = 1 PRT = 0 UTE = -1.5\n+KT1
    = -0.11 KT1L = 0 KT2 = 0.022\n+UA1 =
    4.31E-9 UB1 = -7.61E-18 UC1 = -5.6E-11\n+AT = 3.3E4
    WL = 0 WLN = 1\n+WW = 0 WWN = 1
    WWL = 0\n+LL = 0 LLN = 1 LW =
    0\n+LWN = 1 LWL = 0 CAPMOD = 2\n+XPART
    = 0.5 CGDO = 3.66E-10 CGSO = 3.66E-10\n+CGBO =
    5E-9 CJ = 8.715889E-4 PB = 0.8\n+MJ = 0.3775434
    CJSW = 3.052507E-12 PBSW = 0.99\n+MJSW = 0.1 CJSWG =
    1.64E-10 PBSWG = 0.99\n+MJSWG = 0.1 CF = 0
    PVTH0 = 4.360674E-3\n+PRDSW = -34.2830939 PK2 = -7.347883E-3
    WKETA = -0.0101632\n+LKETA = -0.0452784 )
    TEXT 2216 -208 Left 2 !.MODEL CMOSP PMOS (
    = -0.5312756\n+K1 = 0.8888297 K2 = -0.1 K3
    = 0\n+K3B = 4.096543 W0 = 1E-8 NLX =
    1E-9\n+DVT0W = 0 DVT1W = 0 DVT2W = 0\n+DVT0
    = 0.5419169 DVT1 = 0.4884952 DVT2 = -0.3\n+U0 =
    142.0772561 UA = 2.074059E-9 UB = 1E-21\n+UC
    = -1.44971E-12 VSAT = 1.223249E5 A0 = 0.6650794\n+AGS
    = 0.2234747 B0 = 1.651818E-6 B1 = 5E-6\n+KETA
    = -0.0158936 A1 = 7.712214E-3 A2 = 0.3452462\n+RDSW =
    3E3 PRWG = -0.0851397 PRWB = -0.0758646\n+WR = 1
    WINT = 6.773561E-8 LINT = 1.168451E-7\n+DWG = -1.932882E-8
    DWB = 1.539111E-8 VOFF = -0.0361606\n+NFACTOR = 0.8753188 CIT
    ETA0 = 8.554076E-7\n+ETAB = -3.330273E-4 DSUB = 0.0540144
    PCLM = 1.4696174\n+PDIBLC1 = 0.0346353 PDIBLC2 = 3.22993E-3
    PDIBLCB = -0.1\n+DROUT = 0.9340703 PSCBE1 = 1E8 PSCBE2 =
    5.032622E-10\n+PVAG = 0.0150037 DELTA = 0.01 RSH =
    2.8\n+MOBMOD = 1 PRT = 0 UTE = -1.5\n+KT1
    = 0.5 CGDO = 5.6E-10 CGSO = 5.6E-10\n+CGBO = 5E-9
    CJ = 9.837583E-4 PB = 0.5275652\n+MJ = 0.2031333 CJSW
    = 1E-14 PBSW = 0.5\n+MJSW = 0.99 CJSWG = 6.4E-11
    PBSWG = 0.5\n+MJSWG = 0.99 CF = 0 PVTH0 =
    5.98016E-3\n+PRDSW = 14.8598424 PK2 = 3.73981E-3 WKETA
    = -2.436418E-3\n+LKETA = -2.512206E-3 )
    TEXT 616 56 Left 2 !.tran 10u
  2. John S
    John S Guest
    Yes, it does. But I don't feel like doing it for him.
    John S
  3. Fred Abse
    Fred Abse Guest
    Sheesh! Won't Outhouse Excuse allow you to turn off wrapping? The .models
    are horribly mangled. Newlines in the wrong places and far too much
    whitespace.
    Ten minutes with a text editor to get it to load.
    Basic rules for posting LTSpice circuits: No wrapping, no Greek mu, basic
    ASCII charset.
  4. Andrew Holme
    Andrew Holme Guest
    This has fewer transistors and less overshoot. I put the models in a .lib
    file:
    Version 4
    SHEET 1 3160 752
    WIRE -144 -208 -416 -208
    WIRE -128 -208 -144 -208
    WIRE 112 -208 -128 -208
    WIRE 128 -208 112 -208
    WIRE 528 -208 128 -208
    WIRE 896 -208 528 -208
    WIRE 912 -208 896 -208
    WIRE -416 -176 -416 -208
    WIRE -128 -176 -128 -208
    WIRE 112 -176 112 -208
    WIRE -16 -160 -80 -160
    WIRE 64 -160 -16 -160
    WIRE -144 -128 -144 -208
    WIRE -128 -128 -144 -128
    WIRE 128 -128 128 -208
    WIRE 128 -128 112 -128
    WIRE -416 -64 -416 -96
    WIRE 896 -64 896 -208
    WIRE -128 -48 -128 -80
    WIRE -16 -48 -16 -160
    WIRE -16 -48 -128 -48
    WIRE 848 -48 -16 -48
    WIRE 912 -16 912 -208
    WIRE 912 -16 896 -16
    WIRE 528 16 528 -208
    WIRE -128 80 -128 -48
    WIRE -128 80 -208 80
    WIRE -128 96 -128 80
    WIRE 896 96 896 32
    WIRE 896 96 576 96
    WIRE 112 128 112 -80
    WIRE 192 128 112 128
    WIRE 112 160 112 128
    WIRE 896 160 896 96
    WIRE -208 176 -208 80
    WIRE -176 176 -208 176
    WIRE -128 240 -128 192
    WIRE -128 240 -208 240
    WIRE 192 240 192 128
    WIRE 192 240 160 240
    WIRE 528 240 528 112
    WIRE 528 240 368 240
    WIRE 848 240 736 240
    WIRE -128 272 -128 240
    WIRE 112 272 112 256
    WIRE 368 272 368 240
    WIRE 528 272 528 240
    WIRE 736 272 736 240
    WIRE -208 352 -208 240
    WIRE -176 352 -208 352
    WIRE 192 352 192 240
    WIRE 192 352 160 352
    WIRE 288 352 192 352
    WIRE 320 352 288 352
    WIRE 480 352 464 352
    WIRE -128 384 -128 368
    WIRE 112 384 112 368
    WIRE 368 384 368 368
    WIRE 528 384 528 368
    WIRE 736 384 736 352
    WIRE 896 384 896 256
    WIRE 288 432 288 352
    WIRE 464 432 464 352
    WIRE 464 432 288 432
    FLAG -128 144 0
    FLAG -128 320 0
    FLAG 112 320 0
    FLAG 112 208 0
    FLAG 368 320 0
    FLAG 528 320 0
    FLAG 896 208 0
    FLAG 528 64 0
    FLAG -416 -64 0
    FLAG -128 384 0
    FLAG 112 384 0
    FLAG 368 384 0
    FLAG 528 384 0
    FLAG 896 384 0
    FLAG 736 384 0
    SYMBOL pmos4 -80 -80 R180
    SYMATTR InstName M1
    SYMATTR Value CMOSP
    SYMBOL nmos4 160 160 M0
    SYMATTR InstName M2
    SYMATTR Value CMOSN
    SYMBOL voltage -416 -192 R0
    SYMATTR InstName V1
    SYMATTR Value 3.3
    SYMBOL nmos4 160 272 M0
    SYMATTR InstName M3
    SYMATTR Value CMOSN
    SYMBOL pmos4 64 -80 M180
    SYMATTR InstName M4
    SYMATTR Value CMOSP
    SYMBOL nmos4 -176 272 R0
    SYMATTR InstName M5
    SYMATTR Value CMOSN
    SYMBOL nmos4 320 272 R0
    SYMATTR InstName M7
    SYMATTR Value CMOSN
    SYMBOL nmos4 480 272 R0
    SYMATTR InstName M9
    SYMATTR Value CMOSN
    SYMBOL pmos4 848 32 M180
    SYMATTR Value CMOSP
    SYMBOL nmos4 576 16 M0
    SYMATTR Value CMOSN
    SYMBOL nmos4 848 160 R0
    SYMATTR Value CMOSN
    SYMBOL voltage 736 256 R0
    SYMATTR InstName V3
    SYMBOL nmos4 -176 96 R0
    SYMATTR InstName M8
    SYMATTR Value CMOSN
    TEXT 168 40 Left 2 !.tran 10u
    TEXT 168 72 Left 2 !.include CMOS.lib
  5. Fred Abse
    Fred Abse Guest
    Which is where?
  6. Andrew Holme
    Andrew Holme Guest
  7. Fred Abse
    Fred Abse Guest
    Thanks. There's still a lot of spare whitespace there. This is what I
    cleaned out of Michael's original posting. Looks identical but more
    manageable:
    Quite what "level 49" is, I don't know, unless it's "Level 7 squared" ;-)
    ..MODEL CMOSN NMOS ( LEVEL = 49
    +VERSION = 3.1 TNOM = 27 TOX = 9.3E-9
    +XJ = 1.5E-7 NCH = 1.7E17 VTH0 = 0.5637114
    +K1 = 0.8583586 K2 = -0.0589493 K3 = -2.7574793
    +K3B = 1.1436533 W0 = 1E-8 NLX = 1.564468E-7
    +DVT0 = 0.477499 DVT1 = 0.2847938 DVT2 = -0.3800695
    +U0 = 439.1496114 UA = 1.002561E-13 UB = 1.939998E-18
    +UC = 5.397035E-11 VSAT = 9.657595E4 A0 = 1.0779238
    +AGS = 0.217566 B0 = 9.363617E-7 B1 = 5E-6
    +RDSW = 645.5504862 PRWG = 2.192005E-14 PRWB = -0.1195021
    +WR = 1 WINT = 9.644098E-8 LINT = 9.038343E-8
    +DWG = -1.724548E-8 DWB = -8.255139E-9 VOFF = -0.15
    +NFACTOR = 2.5 CIT = 0 CDSC = 2.4E-4
    +CDSCD = 0 CDSCB = 0 ETA0 = 1
    +ETAB = -0.0136728 DSUB = 1.1083961 PCLM = 0.9566763
    +PDIBLC1 = 2.227565E-3 PDIBLC2 = 4.305101E-3 PDIBLCB = -0.0336439
    +DROUT = 0.0499231 PSCBE1 = 3.326709E8 PSCBE2 = 4.836604E-6
    +PVAG = 0.1980844 DELTA = 0.01 RSH = 4.3
    +KT1 = -0.11 KT1L = 0 KT2 = 0.022
    +UA1 = 4.31E-9 UB1 = -7.61E-18 UC1 = -5.6E-11
    +AT = 3.3E4 WL = 0 WLN = 1
    +WW = 0 WWN = 1 WWL = 0
    +LL = 0 LLN = 1 LW = 0
    +XPART = 0.5 CGDO = 3.66E-10 CGSO = 3.66E-10
    +CGBO = 5E-9 CJ = 8.715889E-4 PB = 0.8
    +MJ = 0.3775434 CJSW = 3.052507E-12 PBSW = 0.99
    +MJSW = 0.1 CJSWG = 1.64E-10 PBSWG = 0.99
    +MJSWG = 0.1 CF = 0 PVTH0 = 4.360674E-3
    +PRDSW = -34.2830939 PK2 = -7.347883E-3 WKETA = -0.0101632
    ..MODEL CMOSP PMOS ( LEVEL = 49
    +XJ = 1.5E-7 NCH = 1.7E17 VTH0 = -0.5312756
    +K1 = 0.8888297 K2 = -0.1 K3 = 0
    +K3B = 4.096543 W0 = 1E-8 NLX = 1E-9
    +DVT0 = 0.5419169 DVT1 = 0.4884952 DVT2 = -0.3
    +U0 = 142.0772561 UA = 2.074059E-9 UB = 1E-21
    +UC = -1.44971E-12 VSAT = 1.223249E5 A0 = 0.6650794
    +AGS = 0.2234747 B0 = 1.651818E-6 B1 = 5E-6
    +KETA = -0.0158936 A1 = 7.712214E-3 A2 = 0.3452462
    +RDSW = 3E3 PRWG = -0.0851397 PRWB = -0.0758646
    +WR = 1 WINT = 6.773561E-8 LINT = 1.168451E-7
    +DWG = -1.932882E-8 DWB = 1.539111E-8 VOFF = -0.0361606
    +NFACTOR = 0.8753188 CIT = 0 CDSC = 2.4E-4
    +CDSCD = 0 CDSCB = 0 ETA0 = 8.554076E-7
    +ETAB = -3.330273E-4 DSUB = 0.0540144 PCLM = 1.4696174
    +PDIBLC1 = 0.0346353 PDIBLC2 = 3.22993E-3 PDIBLCB = -0.1
    +DROUT = 0.9340703 PSCBE1 = 1E8 PSCBE2 = 5.032622E-10
    +PVAG = 0.0150037 DELTA = 0.01 RSH = 2.8
    +XPART = 0.5 CGDO = 5.6E-10 CGSO = 5.6E-10
    +CGBO = 5E-9 CJ = 9.837583E-4 PB = 0.5275652
    +MJ = 0.2031333 CJSW = 1E-14 PBSW = 0.5
    +MJSW = 0.99 CJSWG = 6.4E-11 PBSWG = 0.5
    +MJSWG = 0.99 CF = 0 PVTH0 = 5.98016E-3
    +PRDSW = 14.8598424 PK2 = 3.73981E-3 WKETA = -2.436418E-3
  8. Fred Abse
    Fred Abse Guest
    IOW, PSpice = sqrt(HSpice)?
    Same as 25.806976 = The Root Of All Evil ;-)
    Level 7 isn't in the manual. 4 is BSIM, 5 is BSIM2, 6 is MOS6 (Sakurai &
    Newton), 8 is BSIM3.3.0, 9 is BSIMSOI 3.2, 12 is EKV2.6, 14 is BSIM 4.6.1.
    7 (BSIM 3.2 ??) doesn't appear in the manual. It appears to work, though.
  9. Jeroen
    Jeroen Guest
    It's plenty friendly with this here user. I like it. It's far
    less clickety than what I remember of Pspice. (Which I abandoned
    years ago in favour of LTspice.)
    I agree about the post-processor. In particular, the choice of
    vertical scale divisions never seems to agree with me and it
    can't be made to respect *my* settings from one run to the next.
    Jeroen Belleman
  10. Fred Abse
    Fred Abse Guest
    I'd go along with that.
    That's a nuisance. Every run resets the axes to what *it* thinks.
    Old-fashioned Berkeley 3f4 could be made to format axes the same every
    run. That used gnuplot, AFAIR.
    I wish LTSpice could do polar and Smith plots, and PZ analysis, like 3f4.
  11. Jeroen
    Jeroen Guest
    But LTspice *will* do polar plots. I've done it, but I'll have to
    look into this again to see how I did it. It's not something I do
    very often. The last time, if I remember well, was a polar plot of
    the input impedance of an approximation of a passive constant input
    impedance low-pass filter. My, my, that was seven years ago. How
    time flies.
    As for Smith plots, you can get the shape of the curves with a
    bi-linear transform or by inserting a bridge in your circuit
    somewhere. The axes remain Cartesian, alas. I agree it's nothing
    like the convenience of a VNA.
    Jeroen Belleman
  12. LTspice will make polar plots of complex variables by
    left-clicking the left vertical axis and selecting
    Representation->Nyquist. Is that what you wanted?
    Jeroen Belleman
  13. Fred Abse
    Fred Abse Guest
    I've done it by importing LTSpice rawfiles into 3f4 nutmeg. Needs ASCII
    rawfiles, they get huge.
  14. Fred Abse
    Fred Abse Guest
    No. Nyquist axes are still Cartesian.
    X=real, Y=imaginary.
    What I'd like is "proper" polar. R vs Theta.
    Like Berkeley Spice does.
