CMOS 555 driving BC337 - base resistor
Discussion in 'General Electronics Discussion' started by Cirkit, Aug 1, 2016.
  1. Cirkit
    Cirkit
    132
    10
    Oct 28, 2015
    Hello,
    I am trying to determine the correct base resistor value to drive a BC337 transistor into saturation. The transistor is connected to the output of a CMOS 555 timer via the resistor. The transistor is driving a 3V solenoid which consumes around 200mA when active.
    The entire circuit is powered from 3V.
    With VBE = 1.2V and hFE = 60, I have chosen a 500 Ohm resistor. Is this correct?
  2. Harald Kapp
    11,316
    2,593
    It depends on the operating voltage (or the high output voltage, respectively) of the 555. hFE = 60 means Ib ~ 3.5mA. The required value for Rb is determined by:
    Rb = (Vout_high - Vbe)/Ib
  3. Cirkit
    Cirkit
    132
    10
    Oct 28, 2015
    The 555 is operating in monostable mode and the high output voltage is around 3V.
  4. Harald Kapp
    11,316
    2,593
    Then 500 Ω is a good choice.
    Cirkit likes this.
