CM Chokes sometimes suck
G
George Herold
In the ungrounded lead. As I said, you can probably get away without it.
This is a thermocouple input, and it's heavily lowpass filtered by RCs, and then
by software filtering. The tc cable is a shielded pair. Unfortunately, the tc is
inside an NMR probe, along with high field levels of RF in the 50-500 MHzrange.
The RF did (always will) get into the signal conditioning opamps and get
rectified to small offsets, in a system where 1 microvolt matters. I added this
bead
https://dl.dropboxusercontent.com/u/53724080/Circuits/Filters/Bead_L9...
and it helped by something like 30 dB, and especially broke up narrowband
resonances.
I got this business by doing this better than their previous vendor. An RF
generator could shut down his controller from clear across the room. I'vesold
over 3000 controllers so far, not bad for a "stinkin bead."
"Good bead" :^)
Say if you passed one of the TC leads through it in the other
direction would that make it a one turn CM choke? (Just trying to
expand my transformer understanding.)
George H.
John Walliker
In such unwanted rectification scenarios there is also another option:
Swap the opamp against a CMOS type if one is available that has
otherwise acceptable specs. Those do not have BE junctions behind the
input pins that could rectify.
Yes, very effective indeed.
John
H
Harry D
bead
https://dl.dropboxusercontent.com/u/53724080/Circuits/Filters/Bead_L900.JPG
resonances.
John Larkin Highland Technology Inc
John, your TC signal came into a diff-amp that rectifies at >1.0MHz. My single ended signal, after filtering, comes into a ADC with a bandwidth <1.0MHz. That stinken bead is worthless at <1.0MHz.
W
whit3rd
it's a team effort, you really have no choice now but to leave the CM
chokes in because..
if you convince the EMI guru to take them out now ,,,, and in the
future, there is ANY kind of an EMI issue, it will be YOUR fault.
Yeah, if you're wrong when you say to take them out. It's never
going to be a 'no choice now' situation, though: stand and fight.
The defensive "do EVERYTHING we can" style is bad engineering,
bad tactics. Your job is to use planning time and resources to
good effect, and project hardware bloat is NOT a good effect.
If they don't hurt anything, leave them in and move on.
"No evil, no matter how small, ought to be tolerated." -- Aesop
M
Mark
we are talking about a few pennies worth of parts, i'm not sure I
would use the word evil.
if the EMI guy is responsible for the EMI compatibility issues and he
wants the CM filters in, I would let it go. It's his contribution to
the effort, do not minimize it.
You never know, there may be 5 GHz RF fields and the CM filters help.
You never know, some issue, EMI or otherwise, may come up in the
future and having those CM filter pads on the PWB may be helpful.
It's cheap insurance.
Most importantly, maintaining a good working relationship with other
members of the team is worth ,much more then the few cents for the
parts. If the customer insists on the EMI guy being part of the
team, I would even suggest soliciting the EMI guys input at the start
of the next project.
The real issues here are much larger then engineering.
Mark
Joerg
Jasen said:
Have you killfiled google?
I used to, until my news provider (www.individual.de) began to do a
really good job of hosing off spam. The ads for the fake Gucci handbags
and all that. But it let posts from David Jones (who unfortunately uses
googlemail) through without a problem, something my own filter wasn't
able to do. Then I took my filter out, there is no killfile in my
newsreader.
The news provider occasionally filter out some other legit posts, but
mostly only Jim's, for whatever reason. Maybe they use a routine that a
certain agency lately ... well, let's not go there :)
S
Spehro Pefhany
Clearly Aesop wasn't an engineer.
If the level of evil is guaranteed to be substantially less than the
specified limit, it's probably overdesigned.
josephkk
chokes in because..
Mark
But they do hurt. They cost money. They do not provide the intended
value. And worst of all they teach erroneous design techniques to the
easily swayed. Costing lots of money permanently.
A far better design would use a tapped inductor 2 turns to the outside
world per turn to inside on the two sides of the tap; then place a cap to
ground at the tap. Toroids or closed pot cores preferred.
Measure the performance difference in front of management.
josephkk
If the CM choke is not used then the other lead goes to ground and the signal is "single ended".
But you knew that already.
Cheers, Harry
That is a very different case. The CM choke might actually help. Drawing
the circuit diagram.
___________@@@@___________> to measuring circuit
Therm O=======CMchoke===<_ | |
| _|_ _|_
| ___ ___
|_____|___________|
_|_
//// Pi filter
Do you see how it is not a transformer with a shorted secondary in this
case?
Joerg
Now what's a deecee-bel? Our MBA professors never mentioned ... oh wait,
it's a cheese, right? Yes, it is a cheese!
http://www.thelaughingcow.com/about-us/
