Jamie
i have made a design in the pass using motors as tension drag and was
able to detect the tension so that one could detect the absence of no
tension and thus turn off the machine.
now we have a case using magnetic drag (not friction) clutches and
must be able to detect using only the 2 DC lines used to energies the
field. i haven't disassembled one of these units yet but it appears they
may have a PM (permanent magnet) in the rotor and Fixed coil in the back
plate, from what i can gather from the feel if it there must be poles
because it feels like what a stepping motor would feel like if you were
to have low current in the stepping more and manually turned the shaft.
in any case, this brake unit is part of the mounting plate where mylar
tape is loaded, cable is past through the center of a rotating shaft.
when the tap has tension (not broke or run out), the clutch is also
slipping with a drag in it. this unit is powered by 2 slip rings.
we can not put any more slip rings and because of how the surroundings
are set up, we can not use a strobe tach of any kind and can mount any
wireless devices on the plates. the solution must be of no devices
hanging out in the open in the way.. other attempts of such devices has
proven to not work well or just get broke by the machine operators.
I have already tested for current and voltage changes when the
unit is being dragged, there is no noticeable effects that can be used.
what i purpose is to modulate the DC current slightly at a freq where
the moving PM's over the poles will cause change effects in the wave
that can be detected as a phase shift offset. when the rotor is spinning
and not slipping in the field the phase should not be showing any phase
timing shifts.
of course the modulation level is only going to be no more than abt
5 % of the DC current being applied to the brake field.
what do you think about this idea ?
timing shifts.
