The crystal oscillator that I'm trying to build has to produce some stable
frequency which will be input into a Schmitt Trigger which hopefully will
shape the pulse into a square wave and then will proceed through a series of
Decade counters DIV10 which again hopefully will be input into a number of
counters that will count in 1 second or 1/10th or 1/100th of a second.
Depending on the number of times I divide the frequency. This will then be
displayed on LED designated as minutes, seconds, milliseconds. The longest
time before the clock would have to be reset is 2 min. And it would have to
operate in temperatures ranging from 15 degrees to 50 degrees.
The actual clock would be activated by a magnetic reed switch that would
be passed over a magnet and toggle the clock into On state intially and then
reset about every 2 min. Does this sound like it will work?
Konrad
Yes, that's a trivial circuit. Any crystal based oscillator module or
circuit will do the trick. No need for the schmitt trigger, as the
crystal oscillator circuit will give you a clean TTL square wave
(unless of course you build a crystal sine wave oscillator, but that
would be silly)
Are you using another reed switch to stop the count too?
A reed switch will have a certain amount of latency time to open or
close, you probably won't be able to get 1/100th second accuracy with
a reed switch, more like 1/10th second. But it depends on what you are
doing.
BTW, you wouldn't start and stop the actual oscillator, it would be
free running. You would gate the clock and latch it on/off with a flip
flop.
Regards
