Clock divider by 3 with 50% duty cycle?
Discussion in 'Electronic Basics' started by Davy, Oct 17, 2005.
  1. Davy
    Davy Guest
    Hi all,
    How to Build a Clock divider by 3 with 50% duty cycle?
    Input and output are listed below.
    Clkin
    __--__--__--__--__--__--
    Clkout
    ______------______------
    Any suggestions will be appreciated!
    Best regards,
    Davy
  2. PeteS
    PeteS Guest
    One way to do this is to multiply the clock first (so the clock rate is
    an even multiple of your desired divided clock) and then divide it back
    down.
    There are a number of methods - rate multipliers, for instance.
    Depending on the clock speed and jitter constraints, you might use a
    single chip PLL (Cypress makes some very nice ones).
    Cheers
    PeteS
  3. You design the state machine that your lecturer intended
    you to design, or else you choose to learn nothing by
    Googling for it. Good luck getting a job if you always
    choose the latter path - you'll need it.
    Hint: The state machine produces output transitions on
    edges in alternating directions.
    Clifford Heath.
  4. delo
    delo Guest
    use a toggle flip flop that toggle one time on rising one time on fall ( an
    exor between output and clock
    line ??? only a guess....).
    bye
    delo
  5. see:
    http://www.xilinx.com/xcell/xl33/xl33_30.pdf
    or use a Xilinx coolrunner2 CPLD with coolclock option (triggers flipflops
    on both edges).
    MIKE
  6. Davy wrote...
    This topic comes up every now and then on s.e.d. Here's an
    answer I gave seven years ago, along with some others.
    First my 1997 post, which uses two types of flip flops, one with
    positive-going clocking and one with negative-going clocking. I
    suppose you could use one type of flip-flop with a clock inverter.
    Subject: Re: Divide by 3 Clock
    Newsgroups: sci.electronics.design, sci.electronics.cad
    Date: 1997/04/14
    Anson Chi Fung at says...
    Since no one has answered, Anson, I will. We do have a
    divide-by-3 circuit in our book (AoE fig 8.59), but it doesn't
    meet your specific symmetrical square-wave waveform requirement.
    To meet it, the output must change state on both rising and
    falling clock edges (and of course, the input clock must be a
    square wave).
    I made a design with this feature - matching your waveforms, in
    1979 for a wave recorder at Sea Data. I don't know if it was a
    _minimum_ part design, since it employs 3 flip flops rather than
    two, but it has an additional feature of starting at a proper
    phase after a reset. I hope there aren't any transcription
    errors in this ACSII drawing!
    ,---------------------- J Q ----- out
    clk* --+------------------------------------ CLK*
    | | gnd --- K Q* -,
    | | R* |
    | | | |_ res*-- S* |
    | '- D Q --+___ NOR ------ D Q |
    +--- CLK ,---- CLK |
    | Q*--, | Q*---'
    res* ------ R* '-------------- R*
    The D flops can be a HC74 and the JK flop a HC107 section, etc.
    You can also use a cPLD, if it allows an inverter before a
    register clock, since the JK flop must clock on an opposite
    phase from the D flop.
    Well, lunch hour is over - back to work! Let me know if this is
    helpful, or if you come up with a better circuit.
    Organization: CERN, European Laboratory for Particle Physics
    The following equations describe a divide-by-three circuit which
    will have a 50% duty cycle output, provided the clock also has
    50% duty cycle, exactly as in the diagram above. Signal 'A' is
    your output. '+' is OR and '&' is AND. '/' is inversion.
    A = Ck & A + Ck & B + /Ck & A & C;
    B = Ck & B + /A & B + /Ck & /A & C;
    C = /A & C + A & B + Ck & /A + /Ck & C;
    That's about twelve gates or so, not counting the inversions, and
    no explicit flip-flops. There's a bit of redundancy in some
    equations. You figure out where and why.
    Here is one that I think will work using JK flip flops positive edge
    triggered. My recollection was hazy and I had to rederive it.
    + ---| J Q |---+----| J Q |--+----> Divide by 3 out
    + -|-| K Q'| +--|-| K Q'| |
    _____ | +------+ | +------+ |
    CLK >--| | | | |
    | XOR |--+---------------+ |
    +-|_____| |
    By inverting the clock on each transition of the output, this circuit
    effectively removes two half periods from the divide by 4 circuit which
    this would be without the XOR. Assuming the two flip flops come from
    the same IC (meaning the propogation delays are reasonably well matched),
    the output will be symmetric and the circuit is glitch and hazard free.
    Date: 1997/04/15
    That reminds me of the timeworn phrase, "That's idea's so-oooo crazy, it
    just might work!" As a fan of XOR gates, I remember thinking of an XOR
    approach when I worked on this 20 years ago, but was nervous about the
    glitch factor when playing with the input to an edge-sensitive flop.
    Analyzing the circuit now, it looks pretty good. It even has the "start
    after three half-cycles" phase reset feature of my more complicated
    circuit. Sure, the XOR gate output makes an alarming "runt" clock pulse
    at every output transition, but its length is 2 propagation delays and
    should reliably fire both flops.
    Winfield Hill _/_/_/ _/_/_/_/
    The Rowland Institute for Science _/ _/ _/_/ _/
    Cambridge, MA USA 02142-1297 _/_/_/_/ _/ _/ _/_/_/
    _/ _/ _/ _/ _/
    http://www.artofelectronics.com/ _/ _/ _/_/ _/_/_/_/
    Date: 1997/04/16
    You don't get glitches and hazards in synchronous ccts.!
    Aroosh R. Elahi
    Faculty of Engineering, Carleton University
    Date: 1997/04/16
    Since the clock passes through an XOR, both are possible but this
    implementation should not have them.
    Glitches might occur if the clock were forced to change multiple times
    based on feedback terms. This might result in one or more outputs going
    through two transitions very quickly. Also note that textbook descriptions
    are fine but in the real world, you have unequal propogation delays and other
    effects which can really mess up your entire day! :).
    --- sam : Sci.Electronics.Repair FAQ: http://www.paranoia.com/~filipg/REPAIR/
    If you have not yet been rushed into a solution, you may consider the
    following 50% duty cycle /3 with only 2 D flip flops and an XOR gate.
    It creates the output CLK from the input CLK as you indicated.
    .. Input CLK ---->
    .. XOR >----> CLK D <-|
    .. |--> FF1 |
    .. | |-< Q /Q >-|
    .. | |-> CLK D <-|
    .. | FF2 |
    .. |------------< Q /Q >-|
    .. |-------------------------> Output CLK
    Myron Loewen, Design Engineer, Norscan Instruments
  7. Davy
    Davy Guest
  8. Jim Thompson
    Jim Thompson Guest
    See "DivideBy2p5.pdf" on the S.E.D/Schematics page of my website for
    the basics.
    (You create a reliable trigger/clock on both edges of the incoming
    signal.)
    You just need to rearrange the decoding to get div3 instead of div2.5
    ...Jim Thompson
  9. Jim Thompson
    Jim Thompson Guest
    See...
    Newsgroups: alt.binaries.schematics.electronic
    Subject: Re: Clock divider by 3 with 50% duty cycle? (From S.E.D) -
    Div3-Symmetric.pdf
    Message-ID: <>
    ...Jim Thompson
  10. Jasen Betts
    Jasen Betts Guest
    ["Followup-To:" header set to sci.electronics.basics.]
    If the clock is a fixed frequency just feed it through a resistor
    into a suitably sensitive part of an astable multivibrator
    tuned to approximately the right output frequency.
    for example.
    -+- VCC
    .----------[RX]---}----------.
    | | . VCC(8) . |
    | +--RES(4) OUT(3)----+---
    | . 555 . out
    |\ +-[100K]-+--TH(6) DIS(7)--
    in | \ | | . .
    -----| >O---(-[470K]-+--TR(2) CV(5)--
    |/ ----- . GND(1) .
    | CX |
    `-----------------+--- GND
    Bye.
    Jasen
  11. Guest
    Jim Thompson skrev:
    And to get 50/50 the input clock also needs to be 50/50
    -Lasse
  12. Jim Thompson
    Jim Thompson Guest
    Yep, That's why these "odd-clock" schemes are not often used in
    critical applications.
    ...Jim Thompson
