Clock-dependent signal question
Discussion in 'Electronic Basics' started by Rikard Bosnjakovic, May 17, 2006.
  1. In a project, i have a clock-signal and two other signals (A and B). A and
    B are the opposite of each other - when A is HI, B is LO, and vice versa.
    This project has no microcontroller (or similiar) involved, I have to
    solve it using basic logic components (gates/diodes, TTL/DTL, etc).
    Here's the problem:
    I want signal A to depend on the clock. At each edge-fall of the clock, A
    should change it's state. I.e., when clock goes from LO->HI, nothing
    happens. When clock goes from HI->LO, A goes from HI->LO or LO->HI,
    depending on its current value.
    The value of B is the inverted value of A, so there's no headache for me
    there, but since I haven't worked with signal transitions before I cannot
    seem to find a way for signal A to depend on the clock as described.
    I'm pretty much clueless and I'd be grateful for any hints of how I might
    find a way to solve this trickster.
  2. Greg Neill
    Greg Neill Guest
    Take a look at the gate design for a D-type flip-flop.
    Then do something clever with the Q' output.
  3. Chris
    Chris Guest
    Hi, Rikard. I think you're looking for what's called a Toggle
    flip-flop, sometimes called a "T"-FF.
    Given a clock, you want every negative transition of the clock to
    result in the output of the flip-flop to change state. Also, you'd
    like the T-FF to have complementary outputs, one being the inverse of
    the other.
    You can make a T-FF out of a D-type FF (data-type flip-flop) by feeding
    the inverting output back into the data input. That way, every time it
    clocks, it changes state.
    Unfortunately, I believe all of the commonly available data-type flip
    flops have transition on the positive-going transition of the clock.
    So, you can easily do your logic function with half of a CD4013 (dual
    D-type FF) and an inverter gate, like this (view in fixed font or M$
    Notepad):
    | | VCC |
    | | .------o-----. |
    | | | Vdd | |
    | '--o D Q o--)---A
    | | 1/2 CD4013| |
    | CLK IN|\ | | |
    | o--| >O---o CLK Q'o--o---B
    | |Reset |
    | | Set Vss |
    | '--o--o---o--'
    | GNDGND GND
    (created by AACircuit v1.28.5 beta 02/06/05 www.tech-chat.de)
    http://www.onsemi.com/pub/Collateral/MC14013B-D.PDF
    Hope this is of help. If not, feel free to post again.
    Good luck
    Chris
  4. Ban
    Ban Guest
    I can not make your homework for you, but I will give you a hint. you need 2
    static FFs in series, where the clock for the second is inverted. this will
    need 9 Nand gates and is called Master-Slave RS-FF. The output is fed back
    to the input. The JK-MS-FF has this connection already wired and you have to
    tie the J and K high.
    This basic cell is twice in the 74112. It is used to make a frequency
    divider or in binary counters. You could also use the first stage of a 7493,
    which is an asynchronuos 4-bit counter.
    How comes you pretend to have studied Computer Science and do not know this?
  5. This is not homework, I'm not attending school. I've setup a problem to
    solve to be able to extend my abilities in sequential logic. I'm trying to
    simulate a crossroad with traffic signs. This way - for me - is the best
    way to learn new tricks. Just because you're too naive to make your own
    problems to solve it doesn't mean everybody's like that.
    I will disregard your pompous tone, this time. Don't throw crap on people
    you don't know shit about.
    CS in Sweden does not incorporate any hardware-related material, but a lot
    of software pragmatism. Think of it as software engineering without any
    hardware.
  6. Ban
    Ban Guest
    This is from your link:
    Electrical Engineering, Chalmers university of Technology, 2005-
    So your web page is a lie.
    Well I gave you also some nice part numbers and an explanation. Just get
    lost when you cannot appreciate any help.
  7. Your "help" was overwhelmed with pompous, prejudiced and pointless crap.
  8. Chris wrote:
    [snip]
    Thank you Chris.
    Using a flip-flop with an inverter makes sense, I think. I haven't used
    any flip-flops yet so I guess I will play around a bit with them first to
    get a better grip of how they work.
    Off the shelf without any testing, I think that inverting the clock signal
    before entering the flipflop would yield me the same result, won't it?
    That is, a negative edge-trigger instead of a positive one. I think I will
    test this along with your tip. Both will probably work, and I have a free
    inverter-gate on my board so I don't have to clog up with more ICs.
  9. Rich Grise
    Rich Grise Guest
    He says, as he proceeds to do the kid's homework for him.
    The word, "D flip-flop" comes to mind...
    Cheers!
    Rich
  10. Rich Grise
    Rich Grise Guest
    Yeah, so what? There's a lot of that around here.
    Was it _accurate_?
    And it's considered bad form to get snippy when receiving open-ended
    answers to open-ended questions.
    Good Luck!
    Rich
  11. Yep, and that was the golden nugget in this case. Using a D-flipflop
    together with Chris' tip about feedbacking Q inverted into D-input solved
    this little afternoon project.
    http://bos.hack.org/tmp/cache/traffic_light.pdf
    The reason I built this pretty pointless stuff was because I wanted to try
    to implement an own made timing diagram which I drew yesterday. Instead of
    having a rapid clock and buffer/count the transitions, I used a 7 second
    period clock that immediately feeds the yellow light. The red and green
    light are switched at every 7 second (where the clock edge drop occur).
    Red: HI 7 secs, LO 7 secs, repeat
    Yellow: LO 5 secs, HI 2 secs, repeat
    Green: LO 7 secs, HI 7 secs, repeat
    This circuit will (un)fortunately not replace the existing lights in my
    town, but it was fun to implement a circuit out of a timing diagram.
  12. John Fields
    John Fields Guest
