clipping circuit
Discussion in 'General Electronics Discussion' started by bhuvanesh, Jul 3, 2014.
  1. bhuvanesh
    bhuvanesh
    201
    Aug 29, 2013
    First i admit i am weak on basics.See the image, i am measuring the voltage across the diode.Actually it only passes positive wave,but it also passing negative value.what i misunderstood here.
  2. BobK
    7,682
    1,688
    Look at where your oscilloscope leads are. They are connected to ground and the sine output of the signal generator, of course you will see a sine wave.
    Put a resistor (1K) between the cathode of the diode and ground, and move the scope lead from the anode to the cathode, and see if that changes anything. The scope leads should be on both sides of the resistor.
  3. bhuvanesh
    bhuvanesh
    201
    Aug 29, 2013
    thanks i got that,even though the diode is shorted it have small resistance that make the sine wave appear in output ,right
  4. Laplace
    Laplace
    1,252
    184
    Apr 4, 2010
    You are using a simulation program, so the question is what assumptions the program makes to simulate the real world? Suppose you replace the diode with a resistor, then reduce the resistance in a series of steps (10Ω, 1Ω. 0.1Ω, 0.01Ω, ....) to see how close you can get to a short circuit before the scope shows some effect. In the simulation, how much current can the signal source provide? Is it programmed as an ideal source?
    bhuvanesh likes this.
