M
markp
Hi All,
I'm a little confused by the specs in the MAX9704 class D amplifier
datasheet:
http://pdfserv.maxim-ic.com/en/ds/MAX9703-MAX9704.pdf
Table 2 on page 9 shows that, with a 'gain' setting of 13db with 1.23V rms
input, 15W output power is delivered into 8 ohm load. I can't make this
figure add up! (I assume thie gain is defined as 'voltage gain' which is
actally a power gain figure 6db for doubling of voltage, not 3db). Also
there is a graph showing output power versus load resistance, and this shows
a peak at around 8 ohms - this looks like a classic maximum power transfer
curve, so is there an output impedance to take into account? (it's class D,
so where's the power going?).
Any light shone on this appreciated!
Mark.
datasheet:
Mark.
