Class D audio amplifier recommendation
Discussion in 'Electronic Design' started by Mook Johnson, Oct 5, 2004.
  1. Mook Johnson
    Mook Johnson Guest
    I think Cladd D audio might be a neat thing to play with. I've heard that
    the sound quality can suffer if the component selection is not done
    correctly.
    Any recommended components that have proven themselves with sound quality.
    This will be a bout a 15-25 watt power supply from batteries so it needs to
    be efficient.
  2. Ross Herbert
    Ross Herbert Guest
    |correctly.
    |be efficient.
    There are a number of IC's around for Class D amps (Maxim, National
    Semi, Zetex, NJR etc) but you would have to do all the work necessary
    to get it into a working design. If you wanted to start with a proven
    design you might consider the ZAPpulse from LC Audio
    http://www.lcaudio.dk/com/zp2.htm although this sounds a bit of an
    overkill for your requirements.
  3. analog
    analog Guest
    Check out http://www.diyaudio.com/ and follow this set of links:
    diyAudio Forums > Top > Amplifiers > Digital Amplification, or just
    go here http://www.diyaudio.com/forums/forumdisplay.php?s=&forumid=49
    Do it yourself techniques and advice for building class d amplifiers
    are discussed as well as most commercially available class d amps
    and kits.
  4. Ross Herbert
    Ross Herbert Guest
    On Tue, 05 Oct 2004 03:22:41 GMT, Ross Herbert
    |On Tue, 05 Oct 2004 02:20:18 GMT, "Mook Johnson" <>
    ||correctly.
    ||be efficient.
    You might also take a look at the IR website for Class D design info
    http://www.irf.com/product-info/audio/classddesign.html
  5. Ross Herbert wrote...
    It's surprising to see a list of class-D amplifier IC manufacturers
    without the 800-pound gorilla of class-D IC technology, namely TI.
  6. dd
    dd Guest
    Used a Maxim part DC coupled as a servo driver with complete success.
    TI also have an "alternative" approach which reduces the fundimental
    carrier component and increases higher frequency components to ease the
    LPF design to the point where they claim that the LS inductance does the
    job, any comments?
  7. Pooh Bear
    Pooh Bear Guest
    The performance of Class D can be truly dreadful if not carefully implemented.
    See www.tripath.com
    TI also do some lowish power Class D stuff.
    Graham
  8. Joerg
    Joerg Guest
    Hi DD,
    If there were cables going to the speaker I would feel quite uneasy
    about that.
    Regards, Joerg
  9. Ross Herbert
    Ross Herbert Guest
    On 5 Oct 2004 05:55:31 -0700, Winfield Hill
    |> Ross Herbert wrote:
    |>|| that the sound quality can suffer if the component selection is not
    |>|| done correctly.
    |>|| quality. This will be a bout a 15-25 watt power supply from batteries
    |>|| so it needs to be efficient.
    |>| to get it into a working design. ...
    TI = etc
