Class D amplifier - Power issue?
gibon0695
Dec 2, 2015
27
Dec 2, 2015
27
Hello. I've built a class D amp. I need some help.
Have a look at my video here:
As you can see, amplifier works perfectly to about 75% volume. When I take the volume past this point the speaker output starts to 'chop'.
When I connect just one speaker this problem does not occur, I'm able to turn the volume all the way up and it is LOUD.
However, with two speakers, obviously requiring more current, it doesn't seem to reach full volume without chopping.
The battery I am using is 12V rated at 1-2.4A output current.
The chip is a TI TPA3122: http://www.ti.com/lit/ds/symlink/tpa3122d2.pdf
Speakers are 10W RMS 8 Ohm.
Gain is set at 20dB.
I've checked the data sheet and this battery should be more than enough to power both speakers. Is it possible that the cheap Chinese battery isn't delivering the current it says it can deliver?
Any feedback/help would be greatly appreciated, thank you!
EDIT: These will be useful:
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
Hello
The first thing I would is measure the battery voltage when it's not doing it and when it is. This will tell you if the battery is dropping below the working voltage of the device. Also have a look at the maximum input voltage of the device, you may be over driving the input.
Adam
gibon0695
Dec 2, 2015
27
Dec 2, 2015
27
Hello
Adam
Thanks for the reply.
The battery voltage is 11.6V at the moment, (it is slightly discharged).
The data sheet states that the amplifier operates between 10-30V...
I don't think I'm over driving it as there is no problem when powering just a single speaker.
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
What does the battery voltage drop to when its doing it?
Adam
cjdelphi
Oct 26, 2011
1,166
Oct 26, 2011
1,166
I tend to agree with you, sounds like a lack of available current from the battery...
Better battery time?
gibon0695
Dec 2, 2015
27
Dec 2, 2015
27
Yeah it has to be! I don't have a variable power supply at home so it sucks that I can't hook it up to be sure
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
If the battery voltage stays the same then it's not a current issue, it must be something else otherwise the battery voltage would drop.
Adam
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
The device will most likely have an over current limit circuit, maybe you are asking it to deliver too much current into the speakers?
Adam
gibon0695
Dec 2, 2015
27
Dec 2, 2015
27
Adam
I thought about this. But, I don't think that is the issue, simply because the speaker is much louder when I connect just one of them at a time. That means the speaker can handle the current. This chip is capable of delivering 15W per channel when connected to a 28V supply, I am only aiming for around 3W per channel with my speakers. The speakers can actually driver up to 10W RMS (15W peak).
P= V * I
= 12V * 0.25A
= 3W Per channel (6W Total for 2 speakers)
Total current draw for both channels should be a max of 0.5A at 12V (According to the graphs in the data-sheet).
I can't see how there's a power or current issue... but there certainly is one somewhere!
If the battery is supplying 1A like it says it does, there should be more than enough current? right?
Alec_t
Jul 7, 2015
3,590
Jul 7, 2015
3,590
Battery labels are more likely to specify the Ampere-hour (Ah) capacity than the maximum current they can provide. Can you post a link to the battery spec?
Alec_t
Jul 7, 2015
3,590
Jul 7, 2015
3,590
I can't see anything on the battery label to indicate the battery output current capability. Where did you see the '1-2.4A output current' info? On the charger?
Arouse1973
Adam
Dec 18, 2013
5,178
Dec 18, 2013
5,178
P= V * I
= 12V * 0.25A
Maybe its because you have built the design using varo PCB? Those skinny tracks might be the issue. Measure some of the voltages around the circuit?
Adam
gibon0695
Dec 2, 2015
27
Dec 2, 2015
27
It says in the description of the product on ebay:
"Output voltage: 10.8~12.6 DC"
"Output current: 1-2.4A"
gibon0695
Dec 2, 2015
27
Dec 2, 2015
27
Adam
Possibly, but I had the exact same issue on breadboard, I built it on vero board to see if that changed anything... I will continue to test it, going to hook it up to a power supply when I can
davenn
14,260
14,260
gibon0695
Dec 2, 2015
27
Dec 2, 2015
27
sorry, missed that
the battery is rated at 4800mAh
cant quite read the label on the plugpack ... 12V at some unknown mA rating
it was that bit you got wrong ;)
Just checked the plug!!
"Output: 12.6V DC - 500mA"
Thank you. Lesson learned. Don't trust eBay. Now makes sense why it wouldn't fully power both drivers...
I'm going to hook it up to a Power Supply tomorrow and see what happens, I'll let you know...
I still need a battery though, as this amplifier needs to be portable!
Do you know any good places I get a pretty cheap 12V rechargeable that is capable of supplying 1-2A?
