class AB biasing scheme with MOSFET's
W
Winfield Hill
Jim Thompson wrote...
Took me a *week* of Algebra before I figured out how
saturation was detected (VBE drops).
Drops? I thought Vbe goes up under BJT saturation.
- Win
whill_at_picovolt-dot-com
W
Walter Harley
Mac said:
No apology necessary, since you were right. Thanks for looking it over. I
don't really know of any biasing arrangements for power MOSFET's, so I
just did what seemed sensible to me. I did want to avoid having a bias
adjust pot, but maybe I'll let that requirement drop.
I've seen two topologies for push-pull class AB (or B) MOSFET amps. In one,
like yours, the sources of the P- and N-channel FETs are joined and create
the output. In the other, it's the drains: so, the sources are connected to
the power rails, and it's the P-channel FET that's connected to the positive
rail.
This latter one obviously requires some trickier biasing, and a phase
inverter. And it's easy to make it go "bang". The reason for it is, I
believe, that the gate is always closer to ground than the supply rails.
With the sources-joined topology (like yours), you can't get the output any
closer to the supply rail than Vth (and then some, because output that high
implies a lot of Id, which means that the MOSFET is turned hard on, which
takes extra Vgs - see typical Id/Vgs curves). There might also be some
additional protection against inductive loads, but I haven't thought it
through.
So you either need to be willing to sacrifice a few hard-bought volts of
output (in the MOSFETs, as heat), or you need a high-v gate supply, or you
need the tricky topology with drains connected to output.
These are not really factors in your design; you're talking low power, so
"sacrifice a few volts" is a fine answer. With 15V supply rails, you'll get
11V out, and that's enough to put 10W rms (sine) into an 8 ohm speaker. In
your case, the biasing is not really any different than an ordinary old
BJT-based amp, except that the "Vbe" is a lot higher: instead of voltage
difference of about 1.5v between bases, you need around 4v or 8v or whatever
it is between gates.
By the way, I see people still using BJT's as the bias generator in MOSFET
amps. I don't know why that is; you'd sort of think that you'd want to use
another same-type MOSFET, so as to get comparable temp curves. (That is,
make a Vgs multiplier rather than a Vbe multiplier.) But differences in Id
mean you never get a perfect match; so maybe BJT's are just as good.
John Larkin
What's even scarier is to go back and look at an old design, that you
know worked, but that you now can't figure out why.
Yeah; makes you wonder if you used to be smarter than you are now.
Nah.
John
