Circuit use SST29EE010 Memory
Discussion in 'Electronic Design' started by [email protected], Jan 11, 2005.
  1. Guest
    Is there anything special needed to do from a hardware angle to use
    SST29EE010 Memory chips on a small 68000 system that I am building. In
    the past I have been using 27C512 ROMs for my program and I have had to
    reprogram the ROMs every time a found a bug or add a new hardware
    module. I have now got a comms port up and running and I would like to
    change the ROMs so the the system can reprogram is self on the fly.
    This will reduce the development time and increase the protental of my
    project. Is it a case of hooking up the address, data chip selects,
    read and write lines to the processor and then it is ready to use. Am I
    correct in that all I then need to do is write three bytes of data to
    the correct address followed by the data that I wish to program.
    Thanks for any details that can be given.
    Kenneth Keeley
  2. Paul Burke
    Paul Burke Guest
    You are writing a boot loader. Don't forget that the program for the
    boot loader mustn't get erased when you erase the flash, so either keep
    that bit of the program in a separate EPROM, or don't do 'erase all'.
    Other than that, if the timings are right (and they probably are if it
    worked with EPROM), there's only the slightly different pinout to
    remember- it looks more like RAM than EPROM IIRC.
    Paul Burke
