Circuit to amplify square wave
Discussion in 'Electronic Design' started by [email protected], Aug 4, 2005.
  1. Guest
    I need to build a circuit which will amplify a square wave input from a
    function generator. I have with me an 8V DC power supply that can
    source over a hundred amperes. I had conceived doing the amplification
    using a solid state relay with the square wave driving the input side
    of the SSR. This technique will work if the square wave goes from 0V to
    some finite voltage, say, 5V, as in a TTL signal. But my input is a
    square wave going from -5V to +5V. How do I get my desired
    amplification with just the +8V power supply? I don't have a -8V
    source.
    I have been told that I need to use an opamp for this. This seems like
    a simple task, but I don't know enough circuit design to do this. Any
    help appreciated.
    -SD
    8V----SSR output----load---ground
  2. Without getting into too much detail, look at a switching power supply
    with a dual primary/secondary transformer. Any car audio amp over 50W
    or so will have one you can use as an example. Just cut and paste the
    sections you need.
    There are a couple very good books at your local Borders or Barnes and
    Noble bookstore that cover this very topic if you need to design
    something from scratch.
    Ge0rge
  3. Jim Thompson
    Jim Thompson Guest
    If you have only a single +8V supply, your output is constrained to be
    bounded by 0V and +8V.
    "OpAmp" implies relatively low power output, why "...over a hundred
    amperes"?
    What does "amplify" mean? -5V to +5V input produces what range of
    outputs? Centered at +4V? Minimum always at 0V?
    ...Jim Thompson
  4. Guest
    I do need build the circuit from scratch. Do you of a specific book
    which addresses this problem? I looked in "The Art of Electronics" by
    Horowitz - couldn't find what I'm looking for.
    -SD
  5. Does this need to be a linear amplifier (output amplitude proportional
    to input amplitude) or must it output a constant, high amplitude, in
    spite of changes in input amplitude?
  6. Guest
    opamp is not my idea - it's just hear-say. I don't even know whether an
    opamp needs to be used in the first place.
    I need to pass high currents through my load (here, an electromagnetic
    actuator). The desired current is not steady, but periodically
    switching between +A amperes and -A amperes at frequencies up to 100
    Hz. The actual value of the current A is variable - I will gradually be
    increasing it in steps until my load burns out. The value of the
    current through the load is of importance to me, not the voltage drop
    across it. I used the word amplify to signify that a high power circuit
    is being driven by a function generator, a low power device. I guess
    'amplify' is not the right word in this situation; my bad - a square
    wave pulse on the input side of a solid state relay acts as a gate
    only, and its actual amplitude does not influence the output current or
    voltage.
    I am pretty sure that all I need is the 8V DC power supply box. We used
    to have a box made by a company (which probably doesn't exist now!)
    which did exactly what I want, and using the exact same power supply
    that I have. It's just that it doesn't work and probably parts of it
    are stolen/missing.
    If someone could point me to a book, say, which has this explained, or
    sketch an quick and dirty circuit diagram, that'll be invaluable.
    -SD
  7. Guest
    O.. and by the way, I plan to regulate the current magnitude A by
    either toning down the voltage from the power supply to something below
    8V, or alternatively, keeping the 8V fixed and connecting a
    potentiometer in series with my load.
  8. Tim Wescott
    Tim Wescott Guest
    Your idea of using a solid-state relay (or a pair of them) is valid
    then. Many general-purpose function generators have a TTL-level "sync"
    output that could be used; if you are stuck with +/-5V and the SSR can't
    handle the input you can always use a blocking diode:
    ------>|---o-------
    From | To SSR
    signal .-.
    generator | |
    GND
    created by Andy´s ASCII-Circuit v1.24.140803 Beta www.tech-chat.de
    Things to check for on your SSR are the response speed (100Hz is 10ms,
    the relay should be capable of a fraction of that), current handling
    ability, and ON resistance. If you can't find a DPDT solid state relay
    (do such things exist) to reverse your power then you'll have to make an
    'H' bridge out of four individual ones. This will create a definite
    danger of turning on both relays in one leg of the 'H', causing what
    Zsa-zsa Gabor would call "shoosht through" and the rest of us would call
    "smoke".
    "Amplifier" is more or less correct here -- what folks were fishing for
    was whether you needed to take +/-5V and turn it into +/-100V at 1mA, or
    if you wanted 0V, 8V at 100A -- which appears to be what you want.
    You are looking for a heavy-duty, low voltage, low speed (thankfully)
    'H' bridge. 'H' bridges are dirt common anywhere electrical watts are
    being turned into mechanical watts, so there's lots of choices out there.
  9. Tim Wescott
    Tim Wescott Guest
    (8V)(100A) = 800 Watts. That's quite a big pot. If you can adjust the
    power supply that's probably the way to go.
  10. Jim Thompson
    Jim Thompson Guest
    [snip]
    Your description is clear as mud ;-)
    But it sounds like an H-bridge on the output of your power supply
    might do what you want.
    Can you post a block diagram with performance expectations either on
    newsgroup alt.binaries.schematics.electronic or on a URL?
    ...Jim Thompson
  11. "Simplified Design of Switching Power Supplies" By John D. Lenk
    This is my favorite. It helped me design my first 3KW switcher for an
    automotive amp project I had going. Does a great job at the basics and
    gives plenty of examples.
    The only problem I see you having is with the magnetics. You would be
    well served to consult with a transfomer company to get what you need.
    Many other books exist and are on the shelves at Barnes and Noble or
    Borders. Just do what I did and do a search for "switching power
    supply" on either companies web site.
    Ge0rge
  12. Pooh Bear
    Pooh Bear Guest
    To be honest you clearly need a better grasp of the basics before you
    should consider switching 100 Amps or so.
    What electronics experience *do* you have ?
    Graham
  13. Rich Grise
    Rich Grise Guest
    Just limit the negative excursion:
    Signal Generator +5 ~ -5 ----[470R]---+--- SSR Input
    ---K
    / \ 1N914, 1N4148, etc
    Signal Generator Ground --------------+--- SSR Input return
    Good Luck!
    Rich
  14. Ken Smith
    Ken Smith Guest
    Can you get at both of the leads of the load? Can you seperate the
    frequency source and the amplitude?
    Consider this:
    From
    variable -------+------------------------
    supply ! !
    O S1A O S2
    +--------[ LOAD ]--------+
    O S2B O S1B
    The switches can be arrays of MOSFETs.
  15. Ahh yes, an H-bridge!!!
    Ge0rge
  16. Guest
    Thanks to all those who replied. I think Ken Smith's circuit best does
    what I am trying to do. Ken, I know how to use solid state relays as
    switches in locations S1A, S2A, S1B and S2B in your circuit diagram. I
    have been told that MOSFETs do the same job (as the SSR's) but more
    effectively. I am not too sure how to connect the MOSFETs. An SSR has
    four terminals for low power input and return (function generator in
    this case), and high power input and return (here, the 8V power
    supply). So this makes sense. A MOSFET has only three, right?
    high power input
    signal generator -----| MOSFET
    return
    Where does sig generator return go? Another way of asking the same
    question is, if the two leads of the signal generator get connected
    across MOSFET gate and X, what is X? On the high power side, I assume
    that the two ends of the wire on which the MOSFET is 'mounted' get
    connected across MOSFET source and drain.
    -SD
  17. Guest
    No sir. This seems to chop off one half of my input signal. I can
    easily produce the output of your circuit by halving the amplitude and
    adding an offset in my signal generator. I NEED a zero offset square
    wave (going from +a to -a volts) on the high power (output) side of the
    SSR (or any circuitry used). Thanks.
