Circuit does not simulate
Discussion in 'Microcontrollers, Programming and IoT' started by Practical, Dec 7, 2020.
  1. Practical
    Practical
    7
    Aug 31, 2018
    I tried to run this circuit (simulation) but it does not seem to run.
    i haven't done the program yet, there are 4 buttons each of them change the mode on how the motor operates, e.g if button 1 is pressed the motor will all run at the same time but if button 2 is pressed then 2 of the motor will run separately to the other two.
    this is a reciever circuit, i am yet to make the transmitter circuit, the aim of this is to make a orb/ball controlled by a remote control.
  2. Harald Kapp
    10,833
    2,442
    The image is hard to decipher, letters almost unreadable. Please upload an improved image.
    A few more details, please:
    • What is the circuit supposed to do?
    • What is the simulation result instead?
    • Are there any error messages you can communicate?
  3. Practical
    Practical
    7
    Aug 31, 2018
    Thanks for your reply, i couldn't get a better as i tried to scrreen shot them and they came out similar but i did try to get the values so you could see them, hopefully this is ok but if this is not enough can let me know?
    I tried to screen shot the motor driver and microcontroller so you could see them. I am not used to uploading images, for better quality if you have any suggestion i'll follow them through.
  4. ColKlonk
    ColKlonk
    12
    Dec 22, 2020
    Probably a bit late on this but anyway...
    Your crystal caps (C1 and C2) would usually be connected to DGnd (Digital Ground).
    Could be that the simulator doesn't let the crystal startup.
    Also don't see any power connections to your cpu.
    davenn likes this.
  5. Practical
    Practical
    7
    Aug 31, 2018
    It's never too late and thank you for your reply,
    I connected the (Pin 1) Vpp to 12 volts and connected the Crystal Capacitors to ground but the results continue to remain the same (does not simulate).
    Is there anything else that could help?
  6. ColKlonk
    ColKlonk
    12
    Dec 22, 2020
    Hi, I'm not familiar with the simulator so cannot give you an exact solution.
    Best is to try anything/everything that you have tried yet.
  7. bertus
    bertus Moderator
    1,336
    525
    Nov 8, 2019
    Hello,
    Have you set the power for the PIC in the simulator?
    Bertus
  8. bertus
    bertus Moderator
    1,336
    525
    Nov 8, 2019
    Hello,
    Your schematic is hard to read with all those crossing lines.
    I have added straight lines in red, as I can not edit the circuit (it looks like proteus):
    Bertus
  9. Practical
    Practical
    7
    Aug 31, 2018
    Thanks for your reply, how would I set the power for the PIC in proteus?
  10. Harald Kapp
    10,833
    2,442
  11. Practical
    Practical
    7
    Aug 31, 2018
    The results remain the same and doesn't simulate, is there anything else that can be done?
Similar Threads
Loading...
