I tried yesterday with some odd components lying around, but only had an
NPN transistor, no MOSFET, which resulted in my motor going fast and
slow, instead of fast and off!!
Danny, it will be great to see how this progresses. I am interested in
the reason why the effect on speed is occurring. It sounds like a
problem I am encountering with the 2N3055 NPN power transistor. I do
not find conditions under which it actually shuts off and I do not
understand why. I do know the basic calculation strategies using beta
to determine Ib from a pre-determined Ic, etc. It is maybe noteworthy
that some of these inductor circuits (speakers, transformers, motors,
etc) have variable current draw, so this must mean that Ic will vary.
If one clamps the Vbe and Ib with a fixed voltage and resistance,
respectively, I presume that beta changes. I am quite curious how each
of these parameters effects the others. At least in the case of the
2N3055, it has both low frequency 0.8 MHz, and I suspect slow rise and
fall times and also relatively low beta (between 20 and 70). I suspect
this obligates a very narrow dynamic range. Compare, for instance to a
BD139 with a beta around 160 and frequency of 250 Mhz. Very different.
I suspect the 2N3055 is leaky, but I lack good proof. It came as a
surprise that I could run such inductor circuits a lot better with much
lower power NPNs than the 2N3055. One of the most reliable was a BF658,
which is small signal 1 Watt, Ic 0.12 Amp.
It is also frustrating that the specifications often do not tell what
kind of NPN transistor. I have seen the 2N3055 called a Darlington,
and I have seen internal schematics that clearly show that it is not.
I suspect the latter, and nonetheless, this transistor has not been
real popular with me, despite its massive power rating. I think it is
the low beta (and leakage?) that has made working with it a challenge.
Dominic
