Circuit Breaker connection question
Discussion in 'General Electronics Discussion' started by bowiefan, Feb 25, 2015.
  1. bowiefan
    bowiefan
    3
    Feb 25, 2015
    I have a treadmill that has a simple single pole fuse holder type 15 amp circuit breaker mounted next to the on-off switch on the bottom of unit. When removing the breaker I didn't take note of the wiring. Its a simple two prong female spade connector breaker with reset and there is no indication for proper wire connection, just technical spec writing on one side. Can this breaker have the two wires reconnected either way?
  2. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    Can you take a picture of the breaker and the wires?
    Cheers
    Adam
  3. bowiefan
    bowiefan
    3
    Feb 25, 2015
    Thanks for your reply. Photos of the breaker and connectors.
  4. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    Fine to connect to either terminal.
    Adam
  5. bowiefan
    bowiefan
    3
    Feb 25, 2015
    Thanks Adam
  6. Arouse1973
    Arouse1973 Adam
    5,164
    1,087
    Dec 18, 2013
    No probs.
