Circuit Board Carbon Arc
Discussion in 'Electronic Repair' started by Chris, Nov 4, 2009.
  1. Chris
    Chris Guest
    I have a 55 year old door chime clock and the board has carbon arcs which is
    causing a short. I have seen boards with this problem before and they were
    repaired using some type of filler. What is used?
    Thank you for your help
    Chris
  2. Bob Larter
    Bob Larter Guest
    I'd scrub the board with alcohol & a toothbrush, then spray it with a
    conformal coating. I can't think of any brandnames off the top of my
    head, but I'm sure that many people here will have suggestions.
  3. baron
    baron Guest
    Meat Plow Inscribed thus:
    From the open contact points spark/arc. Though I would have thought
    that it could be cleaned off.
  4. PeterD
    PeterD Guest
    This doesn't sound right, you can't arc with 24 volts. But, if it fact
    it has happened, I'd recommend using a dremel to grind out the bad
    parts of the board, and spray with a insulating coating, or even
    fingernail polish.
  5. Chris
    Chris Guest
    The carbon builds up then it arcs across. If you are thinking that low
    voltage will not arc, you are mistaken. Take a 9volt battery and put steel
    wool across both contacts. It will cause a fire. My kids use to love doing
    this at the kitchen table when they were young.
    Chris
  6. Chris
    Chris Guest
    You can arc with 24 volts. That is like saying a car battery will not arc.
    It happens quite often.
    Chris
  7. GregS
    GregS Guest
    I scrape out the black manually or with a Dremel tool.
    I then coat the bad part with nail polish with a couple coats.
    You could use epoxy if there needs more support.
    Mesure the resistance across the arc points to
    get an idea of the problem first.
    greg
