Choosing microcontroller
Discussion in 'Microcontrollers, Programming and IoT' started by Kashif, Feb 18, 2011.
  1. Kashif
    Kashif
    4
    Feb 18, 2011
    Hi
    I am starting a project about microcontrollers. I have problem choosing one.
    My project will measure speed of an object which will pass through to sensors. The two lasers will fall on some LDR or photo transistor and whenever body will pass through it the laser will cutoff and timer will start, now when body reaches second sensor and cut the laser off. it will stop the timer, and calculate speed.
    I want to inquire which microcontroller should i use?
    Muhammad Kashif
    computersrevealed.blogspot..com
  2. (*steve*)
    25,505
    2,849
    Basically you need one with a timer. That means almost anything.
    The biggest issue is how the result will get from your device to the human who wants to know the result. This will require the most I/O lines (probably) and maybe the bulk of the code.
  3. Kashif
    Kashif
    4
    Feb 18, 2011
    yes i am going to use some pic, will pic 16f877 will be fine. I dont have problem with coding, i can code in assembly and c either. I am stuck that how to ldr's will connect to 16f877
  4. (*steve*)
    25,505
    2,849
  5. Kashif
    Kashif
    4
    Feb 18, 2011
    thanks i am searching on it. You did a valuable task. I will contact you soon if i find any more difficulty.
