Choosing correct capacitor
Discussion in 'Power Electronics' started by bsab44, Jun 21, 2018.
  1. bsab44
    bsab44
    Jun 21, 2018
    I have connected a mini ac alternator to a motorcycle engine to run some led lighting. The alternator specs are voltage range 3-24v, current 0.1A - 1A, rated power 0.5 - 12w. The light bulbs are voltage range 1.5 - 9v ac/dc, output 0.5 - 1w. The system works but I want to connect a capacitor to keep the lights bright when the alternator is running at low rpm. I cannot work out what type or size capacitor would be suitable. Thanks for any advice.
  2. Bluejets
    Bluejets
    5,037
    1,052
    Oct 5, 2014
    Will not work.
  3. Harald Kapp
    11,702
    2,717
    Agreed.
    Use the alternator (plus rectifier and charge controller) to charge a battery. Run the lamps from the battery.
    SOLARWIND01 likes this.
  4. WHONOES
    WHONOES
    1,176
    319
    May 20, 2017
    Have to agree with Harald. It makes most sense.
