choosing capacitor values
Discussion in 'Electronics Homework Help' started by PRIYADHARSHINI, Oct 1, 2014.
  1. PRIYADHARSHINI
    PRIYADHARSHINI
    137
    8
    Feb 6, 2014
    how can we choose capacitor values fro powersupply?
    one is used to remove high frequency
    and another one for eliminating low frequency noises
    what is the advantage and disadvantage of electrolytic capacitor over ceramic capacitor?
    and give the functionality difference between this two
    thanks in advance
  2. shrtrnd
    shrtrnd
    3,822
    519
    Jan 15, 2010
    I'm thinking we need a little more information about your power supply type.
    This used to be a pretty generic question, with electrolytics being the answer (ceramics are mostly used for higher frequency applications).
    Some of he power supplies I'm seeing these days are pretty complex, and can operate at higher frequency.
    Do you know the name of your power supply type?
    Is this for a particular application? (What is the power supply used for?)
    What is the frequency you expect the power supply to operate at?
    Just anything helpful that tells us more about what you need to know.
  3. PRIYADHARSHINI
    PRIYADHARSHINI
    137
    8
    Feb 6, 2014
    normal power supply unit..for AC...at 50Hz for 5v dc
  4. KrisBlueNZ
    8,393
    1,271
    Nov 28, 2011
    This sounds like a homework question.
    I have moved it to the homework help forum.
    What are the differences between ceramic and electrolytic capacitors? Look at the range of capacitance values available in each type. Ceramic capacitors are available with values down to less than 1 pF, and generally up to the low µF range (although there are special MLCCs that go into the hundreds of µF). What is the range of values for electrolytics?
    There are many other differences. You should have been taught this. Go back over your notes, or use Google and Wikipedia to learn more about each type.
    Arouse1973 likes this.
