Chip pin plating
Discussion in 'Electronic Repair' started by Tom Del Rosso, Sep 27, 2006.
  1. I repaired a PC motherboard that was damaged by something that dragged over
    the surface. A QFP's pins were bent sideways and shorted together. I bent
    them back with a dental pick and reflowed the solder, and the board works
    now.
    My question is about the plating that flaked off from the bent pins. It
    looked like nickel or tin. I had to remove it to prevent it from shorting.
    Will that leave the pins vulnerable to corrosion?
  2. g. beat
    g. beat Guest
    You will probably be okay.
    It was likely the tin/lead or tin/lead-free solder on pins.
    If you are saying it scratched the pins. The pins are usually nickel with
    tin plating (other option is gold pins) to make soldering easier.
    gb
  3. mkaras
    mkaras Guest
    The QFPs pins may be plated in nickel over the raw metal of the leads
    but they are most assuredly not made of nickel as the base material.
    Some common materials for lead frame base metals are Cu, Cu-Zr, Cu-Fe,
    Cu-Mg and another composition commonly known as Alloy 42.
    - mkaras
