Chip like LTC1799
Discussion in 'Electronic Design' started by DaveC, Feb 17, 2005.
  1. DaveC
    DaveC Guest
    Looking for alternate part like the LTC1799.
    Its a variable 1kHz - 33MHz, square wave oscillator. Uses single resister
    to control frequency. 50% Duty Cycle.
    DaveC
  2. Was it too hard to look up the linear website ?
    Special functions, Silicon Oscillators.
    They have a bunch of these parts.
    Rene
  3. John Larkin
    John Larkin Guest
    TinyLogic schmitt trigger.
    John
  4. DaveC
    DaveC Guest
    Thanks John and Rene for those two rather flippant replies.
    I have been down the Schmitt road but found that for any variable
    resistor / fixed cap combination the frequency was not selectable.
    I was asking for other manufactures of similar chips to the LTC one. If
    you knew off the tops of your heads that would be quite help full, but I
    can of course do my own research.
    DaveC
  5. James Meyer
    James Meyer Guest
    I saw those earlier replies and calling them "flippant" shows a
    remarkably high degree of restraint on your part. :cool:
    Sometimes I wonder if anyone ever reads more than 5 or 6 percent of the
    words in a post before replying.
    The little LTC1799 is, AFAIK, the only part that does what it does. It
    does it very well too, I might add. I can only surmise that you have a good
    reason for wanting an alternate part. Perhaps the PHB you work for has mandated
    that only second-sourced parts can be used in any design.
    Single-sourced parts can sometimes be a pain, but it's a pain you have
    to learn to live with when you are designing on the "bleeding edge".
    Jim
  6. Guest
    Guest Guest
  7. John Larkin
    John Larkin Guest
    Why flippant? A cmos schmitt will oscillate with a single resistor,
    and the resistor sets the frequency. It might be useful if you don't
    need high frequency accuracy, it's multi-sourced, and very cheap.
    Oh, don't be idea-phobic.
    What's bleeding-edge about a mediocre-accuracy oscillator?
    John
  8. DaveC
    DaveC Guest
    Sorry John, was having one of those days.
    I did try a schmitt res/cap did not get very good results. I'm clocking a
    DAC & ADC so need mark/space within 40-60% and frequency between 20kHz &
    800kHz
    I dont have a scope where I am, but the ADC conversions became error
    riden. When I get back to school in a week I can use a scope so will
    further investigate the schmitt option.
    I need inverters for this circuit any way so the hex chip is not wasted
    on the board.
    DaveC
  9. For 20kHz-800kHz maybe you could use an 8-pin PIC. Just configure it
    to run RC oscillator mode with Fosc/4 output. You don't even need a
    program. 50% duty cycle is guaranteed. ;-)
    Best regards,
    Spehro Pefhany
  10. DaveC wrote:
    (snip)
    Does this mean that any frequency between 20 kHz and 800 kHz will do
    if the symmetry stays between 40-60%, or must that symmetry hold while
    the frequency is adjusted, continuously between these limits?
  11. DaveC
    DaveC Guest
    Yes it must hold, The frequency is controlled by the user. It's for a
    guitar pedal. A foot controller is used to adjust the frequency at any
    time. If the 40-60% mark/space is lost then you get really awful pops as
    the ADC drops samples.
    DaveC
  12. Then I think you could rig up the VCO in a CD4046 or HC4046 PLL to do
    this. 40 to 1 frequency is a bit large, but if you don't need very
    precise limits, unit t0 unit, I think it would work.
  13. Ken Smith
    Ken Smith Guest
    How about:
    A CD4060 / HC4060
    IIRC the oscillator part of the LT1054 runs at about 30KHz. You can
    combine the oscillator with another useful circuit.
    A TICPAL22V10Z could make the oscillator and divide by two with some extra
    sections to make other glue logic.
  14. I read in sci.electronics.design that John Larkin <[email protected]
    landPLEASEtechnology.XXX> wrote (in <[email protected]
    4ax.com>) about 'Chip like LTC1799', on Sat, 19 Feb 2005:
    It operates at around 30 THz? (;-)
  15. Development without a scope can be rather hard, especially when the
    parts don't behave as expected. To get a 50% dutycycle, a Flipflop
    as divide-by-two could be helpful. But only if the slopes are
    sufficiently fast.
    Rene
