Chinese Hiland 0-30V/Audioguru PSU build (down the rabbit hole)
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
The Chinese kit had a 5V1 Zener diode for D7 since it used TL081 opamps. The new opamps use two diodes in series instead. A Zener diode is used with reverse polarity but you installed the two diodes backwards also with reverse polarity. Reverse the two diodes so that their cathode ends are at the negative voltage and they will limit the voltage to -1.3V. On a multimeter a 1N4148 diode should measure 0.6V to 0.7V on Diode Test, your "894" is too high.
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
In the photo above the cathode ends of the diodes are pointing to the negative afaik. Am I wrong?
The 894 reading is the reading over the 2 combined diodes
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
The photo shows the cathodes of the diodes at the cathode end of the old Zener diode D7. But a Zener diode is used in reverse mode, ordinary diodes are used in forward mode. Yours are backwards so turn them around.
Use an ohm meter to measure the pcb trace that connects the anode of the D7 zener diode to pin 4 of U3. That should be the cathode ends of the diodes.
You measured "894" but what? Volts or Ohms? The two diodes in series should measure about 1.2V to 1.4V of forward voltage on a diode test when not in the circuit.
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
Thanks a mil Audioguru. Looks like it's working now. Getting -1.4V on pin 4
The 894 will be 0.894V measuring across both D7 diodes with DMM in diode function. When I pulled the diodes to swing them around I measured them and and I did get about 1.2 V
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
St. Edd
My beta version of transformer winding, now giving 12.1V AC
Now where do I go from here? Just a bridge rectifier or is more required? The meter draws <20mA and requires a supply of 4.5 to 24V
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
When you feed 12.1VAC to a bridge rectifier then at a low current the output of the bridge rectifier is pulses of about 15.7VDC. The meter probably needs smooth DC so add a 100uF/35V capacitor to the output to smooth it.
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
Brilliant Audioguru Thanks
In my meagre supply of electronic components I have 220μf 35V caps. Will that work?
Then for a dummy like me, how do I wire it up, in series in the positive line?
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
220uF will be fine as a filter for the 15.7V pulses. Connect its (-) wire to the (-) wire of the bridge rectifier and connect its other wire to the +15.7VDC that you are smoothing.
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
Display working great with independent transformer winding, bridge rectifier and 220μf smoothing cap:
Thanks again 73's de Edd and Audioguru
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
Audioguru
I think the power supply might be working now but I am still scared that the opamps might have been damaged during my short circuits saga.
Here is a set of voltages taken of the opamps in circuit:
Both pots set to zero
Please have a look if these Voltages are as expected.
Bit dubious about U3 pin 7 at 32V and U3 pin 5 at -1.1V
Thank you for your endless patience. Hoping we can put this saga to bed soon
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
Your meter looks nice and bright and your voltages are good and normal.
U3 pin7 is fine at the unregulated voltage of 42V minus the 10V of zener diode D13.
U3 pin5 is fine because it does not have an offset adjustment pot.
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
Thank you so much for all the help Audioguru.
Now for the tricky job of shoehorning it into a box
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
The heatsinks need air circulation. I can't remember if you are mounting the heatsinks outside the box or if you are using a fan.
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
I am going to be using a fan and shooting for forced air ventilation straight onto the heatsink. Will be posting some photos
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
Heatsink mounting:
The idea is that the fan is going to blow into the box straight onto the 2N3055's. The heatsink will be insulated from the rest of the box so all air goes onto the heatsink and forced up and out:
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
Do you place your fuse before or after the main switch, ie between power plug and main switch or between main switch and transformer?
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
Progress report
My build so far. Still need to pick up a 10 turn pot on Wednesday, so front panel on hold. PCB will be mounted vertically between transformer and big cap. Sure would appreciate it if somebody would tell me if I'm making some monumental stuff up somewhere:oops:
Audioguru
Sep 24, 2016
3,656
Sep 24, 2016
3,656
The fuse should be in series with the electrical input and the on-off switch that feeds the transformer.
bushtech
Sep 13, 2016
1,025
Sep 13, 2016
1,025
Thanks Audioguru
Fuse between power plug and switch in live line. I am using a double pole single throw switch so I am switching the neutral as well.
Question: Now that the power supply has been weaned off the series lamp I am blowing 0.75A slow blow fuses when I switch on. Is this the correct rating of fuse? Power at home here 238VAC.
And the fuses say ATE + some logos and CQ on one side and 0.75A 250V on other side (Glass fuses btw) Are they slow blow?
