child lock on sharp VCRS
Discussion in 'Electronic Repair' started by Eric, Sep 12, 2005.
  1. Eric
    Eric Guest
    Does anyone know how to disable the child lock on a sharp VCR were the
    PINumber has been forgotten?
  2. nvic
    nvic Guest
    usually four zeros
  3. Eric
    Eric Guest
    thanks for that nvic
    Sorry I never got back to you
    I was tring to help someone else out and they have not got back to me
    I had a few other, I fiind via google, but it appears they did not work
    VCM26
    Child lock removal (pin no n/k)
    Press & hold lock key on r/c - lock symbol then displayed, Press & hold
    st/by on r/c & front of vcr for 3 secs. VCR will shut down & clear child
    lock
    Simultaneously press the standby buttons on the
    front panel and the remote control.
    VCMH67
    Childlock removal when PIN not known
    Press "Childlock" on R/C - when display changes to 4 dashes waiting for
    correct code press St/by on R/C & front panel together
    usually four zeros
  4. Eric
    Eric Guest
    thanks for that nvi
    wor
    VCM2
    & hol
    clear chil
    loc
    VCMH6
    fo
    usually four zero
  5. nvic
    nvic Guest
    try unplugging? (after unplugging, wait at least one hour). Also, what
    is the feature called? Also, what model is it? Please let me know, nvic
  6. nvic
    nvic Guest
    I tested other ways of removing the child lock from sharp VCRs. The
    four zeros, i also was able to get it to un set via unplugging.
    sometimes, you can't remove the child lock with these methods. Is the
    child lock called "Tamper Proof" and is there a key symbol in the
    display? If so, check the manual for this info (troubleshooting
    section). Please let me know, nvic
  7. Gerard Bok
    Gerard Bok Guest
    My Sharp VCR unlocks when the play button is kept depressed for 5
    or more seconds :)
  8. Eric
    Eric Guest
    Is that on the VCR or the remote?
    or more seconds :)
  9. Gerard Bok
    Gerard Bok Guest
    Sorry. I have to correct my earlier reply.
    I went to test your question and found out, that my Sharp does
    not unlock on '5 seconds play'. (Akai will though :)
    Sharp has a 'key'-key on the remote control only.
    The manual says, that pulling the mains plug for an hour or two
    will reset the child lock.
  10. Eric
    Eric Guest
    On one old set (can not remember the make, model) I removed the back up
    battery
    Once I even took out the EEPROM and saved it to computer file, cleared it,
    then put the EEPROM back, I think from memory it worked.
