Cheking PWM on board???
Discussion in 'General Electronics Discussion' started by jrd78ep, Mar 22, 2013.
  1. jrd78ep
    jrd78ep
    13
    Mar 21, 2013
    I am troubleshooting a power supply...i found a PWM IC UC3846...any idea how to confirm that PWM IC or any type of PWM IC is working by onboard by voltage reading? I measured Vcc is ok (15Vdc) and Vref read 5Vdc. Please help...i am in new and enjoying this electronic world. Thank u guys...
  2. GreenGiant
    GreenGiant
    842
    6
    Feb 9, 2012
    The only way to check if its working is to measure it with an oscilliscope and look at the waveform.
    If you know what the duty cycle should be and what the peak/trough voltages are you can calculate an approximate of what your multimeter should read if you measure the output pins
  3. Rleo6965
    Rleo6965
    585
    9
    Jan 22, 2012
    If you don't have oscilloscope. You can use multimeter with Frequency function. Most pwm ic run on 20khz on output pin of uc3845 and some higher..
  4. jrd78ep
    jrd78ep
    13
    Mar 21, 2013
    Thanks guys for sharing your knowledge...and hoping someday i can be at your level...
  5. sheldonstv
    sheldonstv
    68
    Jul 17, 2007
    dont forget your isolation transformer.....
