M
Mark Carroll
802.11b wireless networks run on 14 channels from 2.412GHz to
2.484GHz. I want to be able to test the signal strength in different
areas of a building cheaply, but the professional meters are rather
expensive. It would be nice to be able to test the channel strengths
individually, but a measure of signal strength over that whole range
of channels would be better than nothing.
I was wondering if something clever could be done rather cheaply. I'm
out of my depth here, but I was thinking something like:
(a) Can I just attach a little antenna to oscilloscope probes? Can I
get a fast enough second-hand oscilloscope fairly cheaply? 2.4GHz is
pretty fast! Or, do things just not work like that?
(b) Can I make simple little circuits, that have a little antenna,
that resonate fairly specifically with the 802.11b signal (roughly
over the right range, or even for individual channels) enough to build
up a steadier signal that I can measure more easily with a digital
voltmeter or something? (I've made plenty of digital circuits, but
with analog I know little more than how do simple things with RC
oscillators, op amps, etc.) Or, really, anything that responds to the
high-frequency signal in a manner that's easier to detect with cheaper
equipment?
Just looking for ideas. (-: Tiny GHz signals are not what I'm used to
dealing with! I'm not even sure how tuned to the application the
antenna needs to be so long as it's roughly the right length; it's
probably relevant that I'm interested much more in relative signal
strength than being able to accurately measure absolute power, so some
losses in the signal path may be quite acceptable if they're
consistent.
-- Mark
equipment?
consistent.
-- Mark
