G
Guest
I'm new to FPGA and would like to learn how to program/use FPGA in cost
effective way.
What would be your recommendation ?
effective way.
Hi FpgaI'm new to FPGA and would like to learn how to program/use FPGA in cost
effective way.
7 said:That board only runs with windosh ex-pee.
Anyone do same thing for GNU/Linux?
The said:Hi 7
I thought Xilinx did their development software for Linux and Unix systems?
check this link http://www.xilinx.com/ise/marketing/new.htm
Naveed
In said:I'm new to FPGA and would like to learn how to program/use FPGA in cost
effective way.
The book "Digital Design, Principles and Practices" by John F Wakerly
(Prentice Hall) came as a package with the Xilinx "Foundation Series"
student edition for something round the $100 mark. I don't know
anything about current availability or price of this bundle but it was
pretty good value at one stage. The license requires online registration
and will expire after some time (12 months I think but don't quote me)
also the student edition is a bit crippled, from memory there is a limit
on the gate count. The book comes with no hardware, just software but
the software knows how to drive a JTAG off your PC parallel port which
you can build yourself.
UTS has a course where the students built up a kit that connected
to the PC parallel port and it had a small 3.3v FPGA chip with some
buffers to implement a simple JTAG. I don't know if the circuit
diagram is available but maybe a bit of research or some other poster
might be able to point you at suitable hardware.
No linux support in the edition I looked at -- I ran it under Win-98
and it worked pretty smoothly.
It gives you enough to learn about and play with but you would need
something else for any real project.
effective way.
7 said:What is this web edition from both companies!?
Does it need web connection to run?
Does it pass any design information back through this web connection?
Sorry just being totally paranoid - no one likes their
designs stolen.
- Tel
fpga said:I'm new to FPGA and would like to learn how to program/use FPGA in cost
effective way.
Chris S. said:I'm not personally into fpga's, but someone once recommended to me
www.opencores.org as a decent resource for open source hardware.
