Cheap solution for environmental chamber
Discussion in 'Electronic Design' started by David Novak, Jun 27, 2007.
  1. David Novak
    David Novak Guest
    I need to test a product at hot and cold temperatures. Can anyone
    suggest a cheap alternative to an environmental chamber?
    A small freezer would probably be fine for the cold, but what is a good
    solution for hot (50C)? I think a toaster oven would be too hot.
    David
    David Novak
    Dajac Inc.
    17152 Shadoan Way
    Westfield, IN 46074
    Email:
    Phone: 317-258-0223
    Fax: 317-867-1888
    www.dajac.com
    Hardware/Software Consulting
    Headlamp Alignment Equipment
  2. krw
    krw Guest
    Phoenix, about this time of year.
  3. Tim Wescott
    Tim Wescott Guest
    A toaster oven and a (big) lamp dimmer. You'd have to monitor the
    temperature yourself, or make a controller, but it'd do the job.
    Or a toaster oven, a relay, a temperature controller from Omega, and a
    temperature probe from same. "Cheap" may fall by the wayside without some
    inspired eBay buying, but it'd also do the job.
    Tim Wescott
    Control systems and communications consulting
    http://www.wescottdesign.com
    Need to learn how to apply control theory in your embedded system?
    "Applied Control Theory for Embedded Systems" by Tim Wescott
    Elsevier/Newnes, http://www.wescottdesign.com/actfes/actfes.html
  4. Ecnerwal
    Ecnerwal Guest
    Small freezer = insulated box.
    Unplug freezer, run flat power cable inside with small thermostatically
    controlled heater (PTC ceramic disk heaters (with fan) are reasonably
    safe). Set for 50C. Light bulbs and a separate thermostat is another
    classic heating method. Plain old resistive elements...hot is pretty
    easy.
    The freezer plastic interior might object, but if it's only 50C will
    probably be fine. However, a few sheets of rigid board insulation (the
    foil-faced stuff works particularly well) from the building supply and a
    bit of tape (foil if you get the foil-faced board) could make you a
    dedicated hot box easily enough - heat the same way, be able to run a
    batch in hot and a batch in cold at the same time.
  5. Guest
    Small chambers go for around $200 in the surplus shops, provided they
    are the liquid nitrogen type. Full refrigeration costs considerably
    more.
  6. D from BC
    D from BC Guest
    Maybe try:
    http://www.homedepot.com/webapp/wcs...d=10053&productId=100498583&categoryID=500500
    $24.00 at Home Depot
    Or ...
    I do environmental tests in my kitchen oven. I haven't tried 50C but
    my kitchen oven dial has 65C as a min.
    I use a fan in the oven to circulate the air.
    D from BC
  7. Ben Jackson
    Ben Jackson Guest
    If it's really small (eg single pcb) you could get one of those 6-pack
    12V mini fridges. They use a peltier device and usually have a switch
    to choose warming or cooling.
  8. Rich Grise
    Rich Grise Guest
    Find a toaster oven that has a thermostat?
    Good Luck!
    Rich
  9. Rich Grise
    Rich Grise Guest
    You idiot! That's a space heater for heaven's sakes - he doesn't want to
    raise the whole blinkin' ROOM to 50C!
    Try one of these:
    http://www.homedepot.com/webapp/wcs...langId=-1&catalogId=10053&productId=100431020
    Cheers!
    Rich
  10. Down to WallyMart to get a moderatly large (compared with the DUT) camping
    cooler. Drill a hole in the side for a thermometer probe (tight fit).
    Light bulb and fan for heating. Remove light bulb. Insert dry ice for
    chilling. Use a Polish temperature controller (light bulb and switch on the
    fan) to regulate (sort of) temperature.
    Jim
    "Life is not a journey to the grave with the intention of arriving safely in
    a pretty and well preserved body, but rather to skid in broadside,
    thoroughly used up, totally worn out, with chocolate in one hand and wine in
    the other, loudly proclaiming 'WOO HOO What a Ride!'"
    --Unknown
  11. If you have compressed air available, you could use a vortex cooler,
    see wikidpedia
    martin
  12. D from BC
    D from BC Guest
    Could still work.. I don't think the size of that environmental
    chamber was mentioned yet.. :p
    Heck...the OP might be able to insulate a closet and use that as an
    environmental chamber..
    Home Depot has pink foam insulation too.
    I've turned washrooms into paint bake rooms :)
    D from BC
  13. I'll bet the old lady just loved that little stunt.
    Did you at least morph it into a grow room?
  14. Carl Ijames
    Carl Ijames Guest
    My full size gas oven is about 45C when set to the lowest "warm"
    setting - try your oven at home.
  15. Rich Grise
    Rich Grise Guest
    I have a "counter-top" oven that looks a lot like this one, except it's
    white enamel:
    http://homecooking.about.com/od/kitchenequipmentreviews/gr/nesco.htm
    and I don't remember where I bought it or what brand it is, but it's got
    a mechanical thermostat; the lowest indication is 150F, the highest is
    400 or 450F, and at ambient I can hear (and feel) the knob thermostat
    click about half-way up from "off" to "150", so it could probably be set
    as low as 100F, if you have a decent thermometer and time to let it
    stabilize. It's yours for the cost of shipping - make an email by
    concatenating my first and last name and sending it to yahoo, if you're
    interested.
    http://mysite.verizon.net/richgrise/images/RoasterOven.jpg
    CAUTION! 463KB picture file!
    Cheers!
    Rich
    email: richgrise at ya-you-know-what-hoo etc. ;-)
  16. MooseFET
    MooseFET Guest
    You can buy http://www.digikey.com/scripts/dksearch/dksus.dll?Detail?Ref=537548&Row=155665&Site=US
    and a relay to turn on and off a heater AKA big fat resistor or light
    bulb.
    If you put a lot of thermal mass inside the box, the thermostat won't
    have to cycle very often. You can also size the heater so that it
    isn't too strong.
  17. Barry Lennox
    Barry Lennox Guest
    Depends on how big your DUT is.
    There was one in "Circuit Cellar" perhaps 3-4 years back. It used a
    small "auto" fridge with Peltier effect coolers and a couple of WW
    resistors for a heater, together with a small controller. These
    fridges are the size that neatly holds a 6-pack.
    I can find the reference to the exact issue if that helps.
    Barry
  18. Jasen
    Jasen Guest
    clothes dryer?
    refrigerator shell with a heater and a thermostat installed.
    Bye.
    Jasen
  19. David Novak
    David Novak Guest
